Pages (132): Previous 1119 120 121 122 123132 Next
08-10-2017, 12:54 AM
Moley Sounds like a lot of trial and error going on there , but by the sounds of things its turned out well for you Steve.
I've got an Ultimate to get fitted to my car and I'm hoping it will be a more simple install than yours Steve. Just need to find someone to fit it , Confusedmoke:
Thanks. You should be fine if you're just sticking the Ultimate on your supercharged car, a lot simpler than with a turbo installation. All you need is someone who is experienced in mapping them, as you say.
08-10-2017, 12:54 AM #1,201
15-10-2017, 11:43 PM
The other day, I noticed my car goes to full boost *much* more linearly since it was re-mapped. It used to easily go up to 0.6 bar, but then hesitate, and then only went round to full boost (approx 0.9 bar measured) in certain situations.
Now it's very easy to get straight onto full boost, it just goes straight up there if you want it to. I simply hadn't noticed it before, which is probably because I don't use full boost very often lol.
15-10-2017, 11:43 PM #1,202
russelllinn
17-10-2017, 04:53 PM
lol is that true Steve :wink:
that is good news though so it was a positive thing to have the remap :biggrin: i actually have a similar issue so hoping to have that removed when i have another map, going to use a different mapper this time though too..
[Image: AliceTrack-1.jpg]
Have a look at my Scooby project thread here
My garage
Subaru
russelllinn
17-10-2017, 04:53 PM #1,203
My garage
Subaru
LEX11S
18-10-2017, 10:29 AM
steve what type and make fuel pressure reg you using?
LEX11S
18-10-2017, 10:29 AM #1,204
18-10-2017, 12:41 PM
LEX11S steve what type and make fuel pressure reg you using?
I'm not using one at all, nothing more than the OEM fuel system apart from my injectors.
18-10-2017, 12:41 PM #1,205
LEX11S
18-10-2017, 04:45 PM
this is where yours is differnt to mine i dont have the oem one i have a sard one with a fuel return line do you think this could be your prob? i dont get any fault codes like yours come up.
i got told that the oem one wasnt that good for a turbo kit?
dont know if this would help?
LEX11S
18-10-2017, 04:45 PM #1,206
19-10-2017, 05:42 AM
LEX11S this is where yours is differnt to mine i dont have the oem one i have a sard one with a fuel return line do you think this could be your prob? i dont get any fault codes like yours come up.
I'm still running the standard FPR and mines fine, with 550cc injectors.
19-10-2017, 05:42 AM #1,207
19-10-2017, 05:43 AM
I presume the standard FPR is fixed at 1:1 rate as it's normally an N/A car?
19-10-2017, 05:43 AM #1,208
19-10-2017, 07:29 AM
No, it's nothing to do with the FPR etc, I think it's more to do with the stock ECU not coping 100% with having an O2 sim in place (due to what it knows it's trying to do with fuel and then not seeing the expected result ?).
The OEM fuel system seems to be a lot better than some people think, e.g. as Stav has showed with his car. I remember that Wayne used to say that an uprated FPR was good if you were staying with the OEM injectors, to give more of a margin there. But I have uprated injectors anyway.
19-10-2017, 07:29 AM #1,209
CW Racing
23-10-2017, 06:45 AM
I think you need to get this beast down to a TSS event.
CW Racing
Follow our progerss at http://www.cwracing.webeden.co.uk
To become a sponsor Email [email protected]
CW Racing
23-10-2017, 06:45 AM #1,210
CW Racing
Views 6,112
09-04-2024, 01:09 AM
Views 1,571
06-04-2024, 05:57 PM
Views 1,842
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 111,794
25-03-2024, 02:10 AM
Views 10,663
23-03-2024, 03:45 PM
Views 23,392
18-02-2024, 11:42 PM
Views 77,536
08-02-2024, 01:53 AM
Views 503
18-12-2023, 02:55 AM
Views 1,669
08-10-2023, 03:59 AM
Views 3,474
04-10-2023, 03:52 PM
