Pages (132): Previous 1127 128 129 130 131 132 Next
17-01-2019, 03:00 AM
And here's the cal switch (now you see it, now you don't) :
[Image: IMG_1035.jpg]
[Image: IMG_1034.jpg]
17-01-2019, 03:00 AM #1,281
17-01-2019, 03:24 AM
steve why not replace the factory led on the cluster with the toad LED that keeps it with the OEM look of the dashboard......
17-01-2019, 03:24 AM #1,282
17-01-2019, 03:27 AM
Rabster steve why not replace the factory led on the cluster with the toad LED that keeps it with the OEM look of the dashboard......
Yeah, that is something I'd considered (and forgotten). Thanks for the reminder !
17-01-2019, 03:27 AM #1,283
17-01-2019, 03:32 AM
thats ok here to help :p
the updates are looking good so far too
17-01-2019, 03:32 AM #1,284
17-01-2019, 03:37 AM
Rabster thats ok here to help :p
Thanks Smile
Do you think it would be easy enough to install the LED into the dash ? Would it just need an appropriate bezel ?
17-01-2019, 03:37 AM #1,285
Thanks Smile
17-01-2019, 03:40 AM
If you do go down that route, remember the TOAD LED is dual colour, which the stock one probably isn't, and it's the wrong way round for most multi-colour LEDs. Usually you'd have multiple positives with a shared negative but the TOAD one is shared positive and multiple negatives. Also it needs to be a smoked style LED rather than one with a totally clear housing.
17-01-2019, 03:40 AM #1,286
17-01-2019, 03:45 AM
toxo If you do go down that route, remember the TOAD LED is dual colour, which the stock one probably isn't, and it's the wrong way round for most multi-colour LEDs. Usually you'd have multiple positives with a shared negative but the TOAD one is shared positive and multiple negatives. Also it needs to be a smoked style LED rather than one with a totally clear housing.
Thanks, but are you saying it's going to need to be soldered onto the board behind the panel ? I was hoping for a "poke it through the hole" type of solution.
17-01-2019, 03:45 AM #1,287
17-01-2019, 03:47 AM
Couldn't say without seeing the board Smile I imagine that's probably how the stock one is done - it won't be held in with an LED clip because it will be relatively flush mounted, so it'll be held in place by its legs.
You could always attach 1 leg to the PCB for a +ve feed and then run the -ve legs to the TOAD alarm via wires.
Do you remember when I did mine? It's in the MR2's build thread somewhere.
Edited 28-02-2012, 01:22 PM by toxo.
17-01-2019, 03:47 AM #1,288
17-01-2019, 03:51 AM
toxo Couldn't say without seeing the board Smile I imagine that's probably how the stock one is done - it won't be held in with an LED clip because it will be relatively flush mounted, so it'll be held in place by its legs.
I don't remember, no :o , but I will dig it out ! Thanks for the suggestions.
17-01-2019, 03:51 AM #1,289
17-01-2019, 03:55 AM
In the MR2 the alarm LED was a totally separate PCB so much easier to muck around with. Unlikely the IS200 is the same, I would expect the LED circuitry to be integrated onto the main PCB.
Am sure either Stav or Rabs will be able to confirm!
17-01-2019, 03:55 AM #1,290
Views 5,037
09-04-2024, 01:09 AM
Views 1,258
06-04-2024, 05:57 PM
Views 1,469
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 102,649
25-03-2024, 02:10 AM
Views 9,043
23-03-2024, 03:45 PM
Views 19,988
18-02-2024, 11:42 PM
Views 67,510
08-02-2024, 01:53 AM
Views 398
18-12-2023, 02:55 AM
Views 1,467
08-10-2023, 03:59 AM
Views 3,101
04-10-2023, 03:52 PM
