Lexus is200 se
Lexus is200 se
Would a pair of 12" spal fans be a good replacement for the standard fans to give me some more room and would a 550x140x62mm 2.5" intercooler be the right size?
What size fuel return will I need is it an6 and what size feed from the sytec regulater to the fuel rail, do I need an10 oil return and an4 oil feed to the turbo?
I use an6 so should be good.
Oil feed depends on turbo. For ball bearing they need a restrictor I think
I've not found a turbo yet, will I be ok with a an4 feed and if I get a ball bearing turbo I will restrict it.
Is this the pump and regulator I need
just make sure the fuel pump is a genuine walbro one mate not a cheap knock off
With the regulator id suggest getting one with a gauge for easier to set your fuel pressure at 3 BAR at idle.
I will do mate cheers,
Can you tell me what and how many AN fittings and braided line I need for the full conversion
I used an6
That's for the fuel, how about the oil feed and return?
