JapCarForum Cars, Cars, Cars! Project Cars Altezza Build!
Altezza Build!
Altezza Build!
Pages (18): Previous 112 13 14 15 1618 Next
john wan
27-01-2022, 08:48 PM
Ooooo nasty 3mm thick pipes are the way forward bud 😆
john wan
27-01-2022, 08:48 PM #131
Tosh21
27-01-2022, 09:14 PM
The ones we make at work are only .1 thicker than mine and they are fine, f1 stuff is usually thinner than mine is so there shouldn't b so many problems! I think it's the engine vibrations, throwing the turbo about so violently its pulling at the weakest point. I am starting to think I should have just gone 3mm pipe, I may have the lightest manifold in the world bit it's not worth having to weld it up every few weeks Sad
Tosh21
27-01-2022, 09:14 PM #132
john wan
27-01-2022, 10:02 PM
Not if you do a log type one I agree not as nice looking as yours mine sits same place as before an seems to spin up slightly quicker to ��
john wan
27-01-2022, 10:02 PM #133
Bobolish
09-02-2022, 11:17 PM
haha sounds ike what happened when i got my is200, wasn't long before the tail-happy excitement made me learn a lesson! xD
Love the car though and good choice on the wheels!
Bobolish
09-02-2022, 11:17 PM #134
Tosh21
21-02-2022, 11:57 PM
Wrapped some 1.6mm round primary 1 and 2 to try strengthen it to stop it cracking.
[Image: IMAG0433_zpsjqqomxky.jpg]
Seems to be holding up! been a few weeks now with no problem. Plan to pull it off again next week to flatten it right out and give it a proper look over to see if it's cracking and refit with a new gasket and no paste.
Finished lagging the turbo housing too. Came out of the oven with no leaks which is always good! might start to crack once it's on the car and vibrates but it should do a few months atleast. Pressings were too small so had to force it on which made it look a bit rubbish but we'll see how it goes
[Image: IMAG0451_zpsrwt8imep.jpg]
Been thinking about getting another cheap as chips rwd car as a little drift missile I can rag about in while I turn the tezza into more of a full blown project after she's been turbo'd
Tosh21
21-02-2022, 11:57 PM #135
22-02-2022, 09:31 AM
what is that stuff, ive never seen it before?
22-02-2022, 09:31 AM #136
Tosh21
23-02-2022, 09:14 AM
I can't say too much cos each company does it slightly different but basically you put a special insulation material (which was designed for this kind of stuff) onto the turbo housing and then cover it with very thin stainless steel sheet which is dimpled to allow for movement when the exhaust expands and to give it strength. You spot weld the stainless to the body of the turbo making sure it's welded all round to seal the insulation under it. They did a test on a manifold with EGT sensors and a thermo camera, the temp outside the manifold was 450c less so it works very well for retaining heat. It's WAY more expensive than ceramic coating cos it's so labor intensive, not sure if it's quite as good as ceramic coating though
Tosh21
23-02-2022, 09:14 AM #137
FOSSIL FUELS
Moderator
892
24-02-2022, 01:52 AM
That looks cool...
Not seen that before.
Impressive bud
[Image: Supra-logo-toyota-supras-119417_1569_512...duxjro.jpg]
Toyota Supra Aero Top... In 202 Black and 18" GOLD & Chrome's with a BGW Wink
FOSSIL FUELS
24-02-2022, 01:52 AM #138
That looks cool...
Impressive bud
24-02-2022, 03:37 AM
ill stick to ceramic coating then, does look good though
24-02-2022, 03:37 AM #139
Tosh21
26-02-2022, 01:46 PM
Apparently it's way more effective than ceramic coating but like most race car stuff it doesn't last that long and does shake itself to pieces after a while unfortunately.
Finally went to owen developments and got some details on the turbo!
It cost £5000 new! The tr30r is designed to spool mega fast and produce lots of low end power hence the crazy torque figures. Unfortunately this means I can't use it on the altezza cos it revs too high so although it would make boost before I even turn the key, manifold pressure will rise really quickly and it will struggle to dump cos the turbines are so small. They are going to see what it's like inside anyway and will swap me for a turbo more suited to my car with v band mounts and a similar size so that's a bonus! If they can do me a straight swap I can boost before summer which would be amazing
Tosh21
26-02-2022, 01:46 PM #140
Views 1,186
31-10-2023, 10:05 PM
Views 1,671
08-10-2023, 03:59 AM
Views 7,147
06-10-2023, 02:58 AM
Views 3,529
04-10-2023, 03:52 PM
Views 2,286
17-05-2023, 11:25 AM
Views 6,920
05-05-2023, 01:09 PM
Views 988
18-03-2023, 01:09 PM
Views 1,484
07-02-2023, 08:29 AM
Views 3,729
30-07-2022, 06:45 PM
Last Post by Lexus RS200T
