Pages (135): Previous 112 13 14 15 16135 Next
25-04-2019, 08:51 AM
Yep. But reusable, reliable, upto whatever you throw at them.
25-04-2019, 08:51 AM #131
Jimbob-T-Lex
Moderator
1,674
25-04-2019, 11:03 AM
True true ill order them end of the month along with my piston rings and bearings expensive but like you say worth it! ill get some pics of the engine strip down aswell for anyone interested gd for ppl thinking of doing the same
Jimbob-T-Lex
25-04-2019, 11:03 AM #132
25-04-2019, 12:23 PM
Good idea mate take some pics
25-04-2019, 12:23 PM #133
Jimbob-T-Lex
Moderator
1,674
25-04-2019, 01:51 PM
Got loads I'll post tomoz or Thursday anyone find anywhere cheaper than £350 for both sets of arp bolts/studs lol???
Jimbob-T-Lex
25-04-2019, 01:51 PM #134
25-04-2019, 02:20 PM
jimbob150385 True true ill order them end of the month along with my piston rings and bearings expensive but like you say worth it! ill get some pics of the engine strip down aswell for anyone interested gd for ppl thinking of doing the same
I'm interested as well!
25-04-2019, 02:20 PM #135
25-04-2019, 02:21 PM
jimbob150385 Got loads I'll post tomoz or Thursday anyone find anywhere cheaper than £350 for both sets of arp bolts/studs lol???
I thought I paid 100-150 ish for mine so you must be able to get them cheaper.
25-04-2019, 02:21 PM #136
Jimbob-T-Lex
Moderator
1,674
26-04-2019, 12:31 AM
Right here we go pics of the engine strip down and ill get plenty of rebuild as i go along!
This is the engine complete that i got for £350 has 43k miles on it
[Image: IMG_0652.jpg]
First to come off was the timimg belt cover and the vvti sensor
[Image: IMG_0653.jpg]
[Image: IMG_0654.jpg]
Next bit that came off what the fuel rail, injectors,fuel lines and dipstick
[Image: IMG_0656.jpg]
[Image: IMG_0657.jpg]
Next that was taken off was the inlet manifold and rocker cover
[Image: IMG_0658.jpg]
[Image: IMG_0661.jpg]
Leaving the cam shafts on show
[Image: IMG_0659.jpg]
Then the top sproket/gear taken off the the camshaft (Lock off the engine to stop turning on you) and remove the casing at the front of the engine on the head
[Image: IMG_0662.jpg]
Then undo all the bearing caps on the inlet and outlet camshafts (keep in order) and the camshaft will just lift out
[Image: IMG_0663.jpg]
next was the head bolts and i (well my dad used a 12mm spine drive) says it worked fine but in the manual it says these are 10mm bi-hex. These will be replaced ARP bolts/studs anyway
[Image: IMG_0665.jpg]
[Image: IMG_0074.jpg]
[Image: IMG_0075.jpg]
Once these are removed the head will lift off try and keep square to help ensure the shims and buckets all remain they shouldnt go anywhere any how but will be a time consuming job later on in the rebuild
[Image: IMG_06552.jpg]
[Image: IMG_06542.jpg]
[Image: IMG_06532.jpg]
When i bought this engine i was told it had sat around for 6 months in the car but when opened up all is really clean head gasket not baked on, oil still clean and when checking the bores they are smooth with no ridges or scratches so hopefully no need for honing but will wait till pistons are fully out
[Image: IMG_06522.jpg]
[Image: IMG_0651.jpg]
[Image: IMG_0650.jpg]
[Image: IMG_0649.jpg]
Well i hope this helps someone sorry for the lack of detail dads stripping it while im in Ireland so anymore info needed or pics ill try and get for you
Jimbob-T-Lex
26-04-2019, 12:31 AM #137
Jimbob-T-Lex
Moderator
1,674
19-05-2019, 05:44 AM
Just wondering if anyone knows the part number for the crankshaft bearings? Also are these the correct main crank studs i need? thank for help in advance :biggrin:
Edited 29-06-2012, 03:37 PM by Jimbob-T-Lex.
Jimbob-T-Lex
19-05-2019, 05:44 AM #138
19-05-2019, 11:23 AM
Like the pics mate, copied them all as you never know when you need a pic of something.
19-05-2019, 11:23 AM #139
Jimbob-T-Lex
Moderator
1,674
28-05-2019, 02:03 AM
If I get the Walbro fuel pump they ain't no harm in fitting that now instead of when I fit the new turbo engine is there?
Jimbob-T-Lex
28-05-2019, 02:03 AM #140
 7 Guest(s)
 7 Guest(s)
Views 5,120
09-04-2024, 01:09 AM
Views 1,287
06-04-2024, 05:57 PM
Views 102,698
25-03-2024, 02:10 AM
Views 9,073
23-03-2024, 03:45 PM
Views 20,242
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,482
08-10-2023, 03:59 AM
Views 5,976
06-10-2023, 02:58 AM
Views 3,125
04-10-2023, 03:52 PM
Replies 76
Views 2,779
30-09-2023, 01:24 AM
Last Post by RichS11
