JapCarForum Cars, Cars, Cars! Project Cars Altezza Build!
Altezza Build!
Altezza Build!
Pages (18): Previous 113 14 15 16 17 18 Next
26-02-2022, 05:29 PM
bonus! what sort of thing was the turbo created for?
26-02-2022, 05:29 PM #141
Tosh21
28-02-2022, 01:40 AM
WRC cars. Instead of running a restrictor (which can be bypassed with some clever engineering as they used to do back in the day) the turbo has a small compressor so there is no way to bypass it. Because they couldn't make loads of power out of them the engines wouldn't rev that high so it was all low-mid power making lots of torque. So the opposite of an altezza lol would have been nice to have such a fast spooling turbo but I'm pretty confident owens will be able to swap me for a really good turbo
Tosh21
28-02-2022, 01:40 AM #142
johnh
28-02-2022, 10:43 AM
Just got a few pages into you're build, wow I love all the machinend parts you have done. Looks like you prob work at the best place in the world! Very very interesting stuff!
johnh
28-02-2022, 10:43 AM #143
02-03-2022, 03:29 PM
Some excellent parts been made in this build
02-03-2022, 03:29 PM #144
Tosh21
08-03-2022, 12:11 PM
Cheers, it was only good once the clock struck 5 and I could work on the tez!
fitted a new sytec billet filter. £55 compared to the £5 of the normal universal cheap filter but atleast I know it will cope and being serviceable I can keep it for years
[Image: IMAG0473_zps57mr85bp.jpg]
Didn't solve the horrible fpr noise so pulled out the jet pump and returned straight into the tank. Noise instantly went away but the fuel pump still sometimes gets really loud but it is rarer than before. I think the fuel tank breather might be blocked and it,s building loads of pressure. I noticed fuel seeping out of the fitting when I key off after a drive. Fuel is pretty warm too, was thinking about fitting a fuel cooler to keep the pump cool.
Still misfires on idle though and under heavy load so checked fuel pressure while driving with some ghetto gauge fitment
[Image: IMAG0485_zpsbbzqqqyg.jpg]
Pressure didn't move at all through the whole rev range and didn't flicker when it misses under hard acceleration. This rules out fuel delivery being the issue as I know the rail pressure is always constant. Next step is to check injector resistances to see if any randomly change causing the idle misfire.
Start the car and suddenly there is a major misfire, engine is unbalanced and shakes like crazy, e-throttle dies too. Luckily I wasn't far from home so managed to drive her home. Cleared the codes on the code reader and the throttle came back then went onto disconnecting each pack to find the faulty one. Pulled out the faulty coil and it looks like it's been on the car from day one.
[Image: IMAG0487_zpssgvdgrhi.jpg]
Cracked rubber FTW! Arced across into the engine so wasn't getting spark. Covered in electrical tape and it worked really well! bought me some time so I can avoid going to toyota for a new coil.
[Image: IMAG0488_zpshjs7u9xl.jpg]
Don't have a pic but my manifold has finally given way. 3 and 4 have both cracked pretty bad, 2 looks ok but primary 1 which is always the worst has pretty much exploded. When inconel fails it fails in a pretty spectacular fashion so I got pretty lucky that it's only a small pop. The metal has split and peeled back on itself, this stuff is pretty dam strong so must have some major manifold pressure. Not sure why the pressure is so high, maybe because the wastegate pipe is blocked off and there is no turbine in the turbo housing but it would take ALOT of pressure to make it pop.
Gonna repair it on monday and have given up, time to make a steam pipe manifold!
Trying to make one CAD so I can get an idea of how many bends I need and try to make them equal length
[Image: Mega%20turbo%20manifold_zpsmak3cgvr.jpg]
Tosh21
08-03-2022, 12:11 PM #145
john wan
10-03-2022, 09:48 AM
Steam pipe? Handrail manifold ftw dude mines still going strong .
That earth tape is always a winner it's up there with duck tape and cable ties
john wan
10-03-2022, 09:48 AM #146
FOSSIL FUELS
Moderator
892
11-03-2022, 04:56 AM
Glad it was a simple fix in the end...
Shame about the manifold... Patch it up and get some boost Wink
[Image: Supra-logo-toyota-supras-119417_1569_512...duxjro.jpg]
Toyota Supra Aero Top... In 202 Black and 18" GOLD & Chrome's with a BGW Wink
FOSSIL FUELS
11-03-2022, 04:56 AM #147
Tosh21
16-03-2022, 01:18 PM
Owens finally got back to me. The TR30 is definitely a no go, Garrett don't make the parts anymore so it would cost a fortune to repair. They did offer me £400 towards a new turbo though. Not sure when they will get one in but I am soon going to be picking up a brand new GTX28 with a TIAL .86 exhaust housing so I can keep the v-band fitment and externally wasted. Plus it looks much nicer and much lighter. I was tempted to just go for a normal GT28 but with the £400 trade in value I think it actually ends up being cheaper than if I bought a brand new GT28 journal bearing turbo.
Unfortunately, the TR30 has a 2.5inch outlet but the GTX has a 3 inch so my whole exhaust system is useless. Plan to hit it really hard one weekend and make the manifold and exhaust together. In preparation I made some purge bungs and press tools
[Image: IMAG0495_zpsw3oolmnk.jpg]
Also finished the manifold design. It's almost harder to mock up on CAD than in real life!
[Image: MEGA%20MANIFOLD_zpsgrpfi3fw.jpg]
Decided to not bother with a normal collector and just merge the pipes together. Makes it quite difficult to make but much easier to do the rest of the manifold. I think it's a better compromise too as the angles are really shallow even if they are all slightly different it will stop the gasses going into the other pipes so it should flow nicely and all the energy will go into the turbo. All lengths are exactly the same too, it won't be perfectly equal by the time I've made it and it's all shrunk and moved about but it will be close enough.
Will be getting on that in the next few weeks once work calms down a little and I get all the material together. Learnt a lot about making exhausts so the next one will hopefully last and perform really well
Tosh21
16-03-2022, 01:18 PM #148
john wan
16-03-2022, 07:22 PM
Looks an sounds good mate
john wan
16-03-2022, 07:22 PM #149
16-03-2022, 09:28 PM
Nice mate, and decent stuff from Owen.
16-03-2022, 09:28 PM #150
Views 1,186
31-10-2023, 10:05 PM
Views 1,671
08-10-2023, 03:59 AM
Views 7,147
06-10-2023, 02:58 AM
Views 3,529
04-10-2023, 03:52 PM
Views 2,286
17-05-2023, 11:25 AM
Views 6,920
05-05-2023, 01:09 PM
Views 988
18-03-2023, 01:09 PM
Views 1,484
07-02-2023, 08:29 AM
Views 3,729
30-07-2022, 06:45 PM
Last Post by Lexus RS200T
