the gearbox. you can see how far back the shifter will sit.
the gear stick.
this is the adaption plate where the autobox bellhousing will bolt on to.
the gearbox mount.
the engine mounts
the engine might not sit in the same place as before because of the new engine mounts which have to be used for the gearbox and engine to sit in the right place but it might sit as same as before so the plan now is to get the engine back in and get everything connected and see what needs to be altered.
Looking good Asi, your spending lots aren't you :blink:
Good stuff Asi, keep the updates coming !
More pics will come tonight.
the gearbox is all attached with the bell housing etc. one of the bushes are about to give away and i can not find a part number for it as toyodiy has put down all their diagrams so is there any other site???
also looked at the clutch and flywheel. the clutch is uprated helix one which i never knew about. Helix clutches are quite good as i had one in my charged IS and loved the feel of it. hope this one is the same.
Which bush is it exactly Asi ?
