JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lexus IS LED dash kits
31-03-2019, 10:50 AM
LED and SMD are pretty much the same technology, SMD is just a bit newer and appears to be a bit more durable for some reason.
31-03-2019, 10:50 AM #11
31-03-2019, 11:22 AM
Yee as above, SMD and LED both provide light by the same method.
LED = Light Emitting Diode
SMD = Surface Mount Diode
SMD, is basically an LED without any plastic domes on it, which give it a much better light spread and better heat dissipation. But are only good for internal applications because they are not waterproof, and don't have a 'cap' so they need to be under a cover or fascia etc.
31-03-2019, 11:22 AM #12
Fry-Up
31-03-2019, 12:46 PM
I'll have a look for a new set, I can only see the Speedo now cos the engine management light is on :/
Fry-Up
31-03-2019, 12:46 PM #13
IanS200
04-04-2019, 11:47 AM
if you still need some get them from this guy, hes the only one i use and they have lasted over 2yrs.
https://www.crazyleds.co.uk/
IanS200
04-04-2019, 11:47 AM #14
Fry-Up
04-04-2019, 11:50 AM
Yeh I'm waitin til payday, skint at the moment, cheers for the link
Fry-Up
04-04-2019, 11:50 AM #15
04-04-2019, 12:30 PM
These are what you want...
3 x T10
2 x T5
IanS200 you're an absolute legend for finding them!
I've got some T5's the same as that already, they are brilliant because they have a nice thick PCB stalk that fits snug into the holder and stops them wiggling lose.
Whereas the cheaper ones with the thin white plastic bases wobble about and over time they just burn out from the bad connection.
These are ****...as they only have very thin wire contacts on one side
[Image: T5%205050%20WHITE.JPG]
And these are brilliant!...because they have sturdy twin contacts on both sides
[Image: DSCF5902.JPG]
04-04-2019, 12:30 PM #16
3 x T10
2 x T5
Fry-Up
14-05-2019, 05:38 AM
Crazyleds.co.uk
[Image: Cover.jpg]
Fry-Up
14-05-2019, 05:38 AM #17
Crazyleds.co.uk
[Image: Cover.jpg]
jameshunter
16-06-2019, 03:17 AM
ro you u could go full custome lights smd
[Image: 8A857D62-orig.jpg]
[Image: 44681127-orig.jpg]
jameshunter
16-06-2019, 03:17 AM #18
16-06-2019, 04:15 AM
there well bright. sam will be impressed with the purpleness of them
16-06-2019, 04:15 AM #19
jameshunter
17-06-2019, 07:56 PM
Took me for for what felt like forever to do this .never again lol
jameshunter
17-06-2019, 07:56 PM #20
Views 925
06-11-2022, 01:49 AM
Views 414
18-10-2021, 02:04 AM
Views 361
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 576
03-09-2021, 11:04 AM
Replies 35
Views 8,066
04-08-2021, 04:34 AM
Last Post by cjoseph
Replies 128
Views 7,357
20-08-2020, 09:09 AM
Last Post by Fry-Up
Views 828
05-08-2019, 12:42 PM
Last Post by mattlaw
Views 440
28-06-2019, 10:43 AM
Last Post by purplewitch
Views 493
05-05-2019, 11:07 AM
Last Post by is200iain
