JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Vacuum bypass valve
Vacuum bypass valve
Vacuum bypass valve
04-03-2021, 11:56 PM
Making a custom mount mate.
04-03-2021, 11:56 PM #11
marko45
05-03-2021, 12:12 AM
Someone can tell us the difference between this valve and the original TTE one ?
marko45
05-03-2021, 12:12 AM #12
05-03-2021, 12:29 AM
This runs on vacume where the tte on is operated by a cable thats attatched to the throttle
05-03-2021, 12:29 AM #13
Or at least thats what I think is the difference
05-03-2021, 12:29 AM #14
marko45
05-03-2021, 12:40 AM
Yeah i knew that "mechanical" difference but i meant the feeling when driving. Do you really have full boost at low rpm?
marko45
05-03-2021, 12:40 AM #15
rob
05-03-2021, 12:59 AM
marko45 Yeah i knew that "mechanical" difference but i meant the feeling when driving. Do you really have full boost at low rpm?
Really ? just think about it for a second! Pressure is produced by the sc spinning at max engine rpm. Low engine rpm low boost.
It does totally change the way it is delivered though.
rob
05-03-2021, 12:59 AM #16
rob
05-03-2021, 01:06 AM
Who has a photo of the mini one? Might jog my memory why it didnt work easily.
rob
05-03-2021, 01:06 AM #17
phaebo
05-03-2021, 01:17 AM
You can drill new holes and put some bolts in there.
I have not mounted this on my charger bit i know some others did it.
phaebo
05-03-2021, 01:17 AM #18
05-03-2021, 01:30 AM
Ive made a custom mount which goes on a t piece
05-03-2021, 01:30 AM #19
05-03-2021, 01:33 AM
I went to sheet metal guys and they are going to make a mount for it. All you need is a pipe coming from back of charger and then add a pipe on to it like a T piece with 3 bolting points for bypass to secure on to.
lexusdaydreaming
05-03-2021, 01:33 AM #20
 3 Guest(s)
 3 Guest(s)
Views 554
27-08-2023, 03:56 AM
Last Post by phaebo
Views 467
06-04-2023, 02:00 AM
Views 917
28-09-2022, 06:39 AM
Views 200
30-06-2021, 10:51 AM
Last Post by phaebo
Views 255
20-03-2021, 10:31 PM
Views 663
14-02-2021, 09:05 PM
Views 778
27-01-2021, 12:25 AM
Last Post by reganlives
Views 217
07-03-2020, 12:49 PM
Views 629
16-03-2019, 08:58 AM
