JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning IS200 Starter Button
04-09-2016, 11:12 AM
Sparkystav I DID, but that ones not mine, thats a proper S200 one.
Not you dont need to change the starter motor or anything like that.
yes you still need to turn the key to position two, then press the button.
its pretty simple. get the switch, and a normal car relay.
go from a 12v to the switch, then to the relay coil, then to earth.
then you need to get under the steering column and attach to the white wire with red stripe on one side and the black wire with white stripe on the other.
so when you press the button, the relay closes and joins the starter to the 12v supply, starts the car, then let go of the switch, the relay opens and the starter motor stops.
REMEMBER though the wires going to the starter motor and power need to be at least as thick as the wires your joining to as theres quite a current pulled.
The one to the switch doesnt have to be that thick.
heres the wiring diagram:
http://www.bahamutcars.com/workshop/IS_9...ml?code=ss
hope this is understandable
I think i understood what are you talking about. Once i get the s2000 button i will post some pics of the wire connection. If i have any problems :w00t: i will pop you a pm if thats ok mate. :lol:
04-09-2016, 11:12 AM #11
04-09-2016, 11:22 AM
Rabster i have the remote start feature too i have a link for a 2nd gen is start button some where will dig it out when i get home for you looks much nicer imho
Was it hard to sort the remote start? Have you got a proper kit (i.e. expensive) or was it not too much?
04-09-2016, 11:22 AM #12
04-09-2016, 02:50 PM
After some search on the web i found this good review
http://www.isfanatics.com/forums/showthread.php?t=64
04-09-2016, 02:50 PM #13
04-09-2016, 09:55 PM
good little write up that
04-09-2016, 09:55 PM #14
05-09-2016, 08:49 AM
Yep a good write up - the position works really well in LHD cars, on RHD cars it's a bit out of the way imho.
05-09-2016, 08:49 AM #15
Views 279
20-01-2024, 07:39 AM
Last Post by cjoseph
Views 981
28-05-2023, 02:46 PM
Last Post by bigdave1701
Replies 47
Views 3,240
08-12-2022, 09:37 AM
Views 309
20-04-2021, 11:46 PM
Last Post by lexusdaydreaming
Views 834
23-03-2021, 07:29 AM
Last Post by kaykay
Views 368
15-09-2020, 02:23 PM
Replies 31
Views 1,941
25-07-2020, 07:50 AM
Replies 103
Views 6,206
31-03-2020, 07:02 AM
Last Post by Barry
Views 389
30-10-2019, 05:26 AM
