JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza IS2 Lowering Springs
17-11-2017, 09:07 AM
Coilovers will be a *lot* better than lowering springs (possibly adjustable, ride not compromised when lowered etc), and cost no more to fit. So saving your money for coilovers will be no bad thing !
17-11-2017, 09:07 AM #11
James S
17-11-2017, 09:27 AM
Would it be difficult to fit coilovers myself?? Its just with them being pre-tensioned??
James S
17-11-2017, 09:27 AM #12
17-11-2017, 09:37 AM
James S Would it be difficult to fit coilovers myself?? Its just with them being pre-tensioned??
Not too hard, no. Others who have done it themselves will be able to give you better advice.
Don't forget though, when you change the ride height of your car you will need the chassis geometry recovering (e.g. a trip to WIM), or you will have tyre wear problems and poor handling.
17-11-2017, 09:37 AM #13
James S
17-11-2017, 10:36 AM
Yeah I know, will have to sort that closer to the time. But might certainly try and get them on myself then spend some cash on getting WIM to fine tune them! :laugh:
James S
17-11-2017, 10:36 AM #14
Andy-R.
17-11-2017, 02:16 PM
Coilcovers should be easier to fit than springs as you drop the whole unit out and replace with the coilcover, with springs you have to clamp them to get them off the shock making it slightly more difficult, I want coilcovers eventually but for now the springs will defo do me I can't stand how high my car sits.
[Image: Lf9Nl.jpg]
Andy-R.
17-11-2017, 02:16 PM #15
[Image: Lf9Nl.jpg]
17-11-2017, 02:27 PM
If you have a set of spring clamps its no problem to do them yourself. Me and a mechanic mate did mine in my garage Big Grin
17-11-2017, 02:27 PM #16
17-11-2017, 04:26 PM
Coil Overs are easy to fit - so long as you are a half way decent DIY mechanic. I did my own, however I did borrow the ramps and tools of a local garage for easy access, and there was a mechanic around if there was a problem. Take your time and if you don't have a good memory photograph the fittings before you remove anything, then you have a reference to work from.
17-11-2017, 04:26 PM #17
James S
18-11-2017, 07:58 AM
Good thinking, going to get saving, hopefully should have enough by end of Jan.
James S
18-11-2017, 07:58 AM #18
18-11-2017, 09:26 AM
The trouble with lowering springs is that although they're designed to go with the stock dampers, the other way round doesn't apply - i.e. the stock dampers weren't designed for use with shorter springs, so their full travel isn't used and ride quality suffers as a result. I only really notice it going over bumps, and it's much harsher on that sort of thing.
18-11-2017, 09:26 AM #19
James S
18-11-2017, 10:22 AM
Yeah, and my dampers are now 10year old, so if I put more stress on them now, they might just give up!
So yeah, going to get some BC racing coilovers ordered by end of Jan.
James S
18-11-2017, 10:22 AM #20
Views 332
14-03-2023, 03:34 PM
Last Post by VVT-Einstein
Views 530
23-11-2020, 11:51 AM
Last Post by sprinter2012
Views 306
26-07-2020, 05:01 AM
Views 511
11-07-2019, 04:29 PM
Views 795
07-01-2019, 08:33 AM
Last Post by deckie77
Views 2,216
05-01-2019, 09:11 PM
Views 948
24-05-2018, 04:39 PM
Last Post by Andy-R.
Views 605
22-07-2017, 06:07 PM
