JapCarForum General Discussions The JCF Lounge Wireless router in cupboard
25-12-2016, 04:31 AM
rig-pig my one has been working fine in the cupboard for years its kind of in the mid of the house and i still get a sig in the garage no probs and its the bt hub i have
Awesome, it'll be essentially where it is at the mo so location won't change, it'll just be in a cupboard rather than outside as it currently is.
One other slightly odd question, does a network socket just have a plug on the back for a normal network cable or does it require some wiring?
25-12-2016, 04:31 AM #11
25-12-2016, 04:38 AM
how do you mean mate? most houses don't tend to have network sockets in them more RJ45 phone sockets which you put (depending on type of internet e.g. cable/adsl) a filter to thr phone socket then from the filter you split a adsl cable to your router then a phone cable to your landline.
25-12-2016, 04:38 AM #12
25-12-2016, 05:18 AM
Dan_Turism0 how do you mean mate? most houses don't tend to have network sockets in them more RJ45 phone sockets which you put (depending on type of internet e.g. cable/adsl) a filter to thr phone socket then from the filter you split a adsl cable to your router then a phone cable to your landline.
This is a bit random, but I just wanted to know about network wall sockets - if you wanted a socket in one place and another in another place - but all the two sockets would do is to connect the two locations, nothing else.
And what the wall sockets have behind them - are they like AV sockets which you still use a normal cable buried in the walls and plug them in to the back of the socket or are they like telephone sockets and require wiring?
25-12-2016, 05:18 AM #13
25-12-2016, 05:33 AM
yes it's possible and fairly straight forward however have you thought about using powerline adapters instead?
25-12-2016, 05:33 AM #14
25-12-2016, 07:14 AM
Dan_Turism0 yes it's possible and fairly straight forward however have you thought about using powerline adapters instead?
Yep I am currently using those as well, but while they're quick it's not as quick as a direct network connection - so I have a plan while doing a bit of redecorating to put network sockets in where I can.
Just wanted to know whether it can be a DIY job for a complete novice like me or would I need someone who knows what they're doing Smile
25-12-2016, 07:14 AM #15
redz
25-12-2016, 07:19 AM
if you buy cat5 cable and the facia plates then its quite simple.
you just connect the cable to the back of the facia (similar to a phone socket) and job done..
i have done this through the wall and outside the house and back in again upstairs..
redz
25-12-2016, 07:19 AM #16
might be worth dropping toxo a pm on here mate Smile he's our network engineer where I work :p
25-12-2016, 07:19 AM #17
25-12-2016, 07:40 AM
redz you just connect the cable to the back of the facia (similar to a phone socket) and job done..
That's perfect, exactly the sort of thing I want to do.
Dan_Turism0 might be worth dropping toxo a pm on here mate Smile he's our network engineer where I work :p
Cool, will bear that in mind if I have any technical questions Smile
25-12-2016, 07:40 AM #18
Replies 25
Views 1,012
29-03-2019, 08:38 AM
Last Post by Cyntax
Views 725
06-02-2018, 01:47 PM
Last Post by Jambo
Replies 36
Views 1,714
04-01-2018, 01:00 PM
Replies 33
Views 1,202
19-10-2017, 02:20 AM
Views 484
30-09-2017, 06:40 AM
Last Post by Carpediem
