JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Front fog not working.
03-06-2016, 12:44 PM
The boot light could have stopped working because of a problem with the switch that makes it come on when the boot opens. That's not connected with the front fogs, no. Unless you've got some sort of water-related electrical problem that is messing up multiple relays and/or ECUs (not sure that is too likely though).
I really would consider investing in a cheap multimeter from Maplin's, B&Q or somewhere like that so you can check if the voltage is coming through to those respective lights.
03-06-2016, 12:44 PM #11
Andy-R.
04-06-2016, 11:22 AM
steviewevie The boot light could have stopped working because of a problem with the switch that makes it come on when the boot opens. That's not connected with the front fogs, no. Unless you've got some sort of water-related electrical problem that is messing up multiple relays and/or ECUs (not sure that is too likely though).
I thought that about the switch but can't find it, not really had a proper look but I think it's connected to the release rather then the push type you get on doors, don't think it's a relay issue because everything else is fine:confused1:
[Image: Lf9Nl.jpg]
Andy-R.
04-06-2016, 11:22 AM #12
[Image: Lf9Nl.jpg]
Views 204
01-07-2020, 04:42 AM
Views 623
02-08-2019, 08:39 AM
Last Post by jasons
Views 309
28-07-2019, 04:57 AM
Last Post by Matt_C
Views 328
19-07-2019, 12:48 PM
Last Post by Chris0121
Views 385
28-06-2019, 10:43 AM
Last Post by purplewitch
Views 835
01-04-2019, 04:02 AM
Last Post by lookatmybiceps
Views 360
15-01-2019, 05:15 AM
Last Post by avi_444
Views 1,138
28-11-2018, 10:22 AM
Last Post by sprinter2012
Views 724
28-09-2018, 11:44 AM
