JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza TRC and VSC light on
06-10-2017, 11:14 AM
steviewevie Surely that'll bring up an engine check light and a code though ?
yes it does and should as phil says 'scan gauge did not pick anything up, only o2- sensors 2 bank 2, this has always been on and the heater elements is knackered on it Scan gauge did not pick up any other fault'
so is b2s2 the only problem or are there other gremlins hiding away too that the SC is not detecting? :confused:
06-10-2017, 11:14 AM #11
06-10-2017, 11:36 AM
Ah sorry, missed the bit about the scangauge showing that code.
06-10-2017, 11:36 AM #12
Phil01
06-10-2017, 11:41 AM
b2s2 has been on for the last 3000 miles and has not caused these new warning lights to come on before, it only happened last night.
b2s2 does not cause it to go into limp home mode as it is only the heater circuit that is not working, the actuall fuel trim side of it is doing its job, as I have checked it with a volt meter.
All that has come on is the TRC off and VSC steady illumination not flashing, no other lights, nor ABS are on.
Just need to find a proper multifunction code reader that can read all codes, ABS,airbag, aircon etc
Phil01
06-10-2017, 11:41 AM #13
06-10-2017, 12:03 PM
How about trying that procedure that doesn't need a code reader ?
06-10-2017, 12:03 PM #14
Phil01
06-10-2017, 01:13 PM
I will try that at the weekend steve, hopefully that procedure shall output a code,
Will keep post updated.
Phil01
06-10-2017, 01:13 PM #15
06-10-2017, 01:27 PM
We need another toyota product dad Wink
06-10-2017, 01:27 PM #16
Phil01
06-10-2017, 01:41 PM
Stop trying to make me buy a JZA80. maybe in the New Year
Phil01
06-10-2017, 01:41 PM #17
06-10-2017, 01:46 PM
oh yes, not trying to imply you know the technical word for it
and noooooooo
06-10-2017, 01:46 PM #18
and noooooooo
Views 520
25-06-2021, 08:14 AM
Views 300
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 546
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 312
16-09-2020, 08:21 AM
Views 373
30-07-2020, 12:35 AM
Last Post by Dinho
Views 324
28-03-2020, 10:39 PM
Last Post by James S
Views 510
10-03-2020, 11:17 AM
Views 303
10-03-2020, 08:16 AM
Last Post by Colin G
Views 240
23-10-2019, 03:14 PM
Last Post by Jk 200sx
Views 463
10-10-2019, 05:16 PM
Last Post by MrGash
