JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Hazard lights and drivers door open shut sensor
James S
27-11-2017, 08:54 AM
Been out and had a closer look at the car today.
And on closer inspection, both front door switches arn't working.
If you open both the front doors, the inside light doesn't come on, neither does the light on the dash board. Also the rear boot release on the key fob doesn't work.
Could I have a fuse out??
James S
27-11-2017, 08:54 AM #11
mattlaw
27-11-2017, 10:31 AM
I'd be checkin the fuse box in the drivers kick panel for any water damage
mattlaw
27-11-2017, 10:31 AM #12
27-11-2017, 11:57 AM
boot lock could be if its been locked by the key in boot lock as i think this stops it popping same as it disables the internal handle.
i think its unlikely to be a fuse as i think the interior lights are all on the same fuse, the switch is just a short to ground so you can check this by taking the trim off locating the wire which goes up the B pillar
Dont cut this wire instead use a stanley knife and a multimeter hold the blade so its nicking through the PVC of the cable and then hold a multimeter probe on the blade other probe to a bare bit of chassis metal maybe the Seat belt tensioner.
If memory serves this should produce a short to ground if you push the button in then the ground be gone.
be sure to check the wire is connected and not floating loose in the B pillar...
Rabs
27-11-2017, 11:57 AM #13
Rabs
iceman67
Unregistered
195
27-11-2017, 03:18 PM
james check the boot lock to see if it has been turned round if it has the disabling of boot opener could be that its in valet mode as for door switches check with a multimeter to see if they are switching n/o and n/c hope this helps mate all the best neil
iceman67
27-11-2017, 03:18 PM #14
James S
28-11-2017, 12:53 AM
Going to have to nip round to my sparky mates house me thinks. Never been right good with electrics! LOL!
Thanks everyone, will check the boot lock, but think the lock is in the upright possition.
James S
28-11-2017, 12:53 AM #15
28-11-2017, 06:08 AM
iceman67 james check the boot lock to see if it has been turned round if it has the disabling of boot opener could be that its in valet mode as for door switches check with a multimeter to see if they are switching n/o and n/c hope this helps mate all the best neil
The key turning doesnt disable the key button, just the handle in the car.
28-11-2017, 06:08 AM #16
Views 1,176
02-11-2022, 10:55 AM
Views 178
23-01-2021, 07:58 AM
Views 159
07-10-2020, 01:46 AM
Last Post by Stoney
Views 286
23-10-2019, 06:59 AM
Last Post by reganlives
Views 311
19-09-2019, 08:41 AM
Last Post by jomo
Views 461
12-09-2019, 02:13 PM
Last Post by IanH
Views 502
15-05-2019, 05:06 PM
Last Post by Mr Reman
Views 303
10-05-2019, 04:47 AM
Last Post by Fry-Up
Views 285
09-05-2019, 12:39 PM
Last Post by jasons
