JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Driving along...suddenly my coolant warning light lights up!
12-06-2017, 04:39 AM
Glad you got it fixed mate
12-06-2017, 04:39 AM #11
kam05
12-06-2017, 04:50 AM
steviewevie Did you check your oil level ? How low was it ? Just curious as to how low it needs to be to make the warning light come on (hope I don't find out through a practical example !).
I totally forgot about updating this. Yep- checked the oil level, it was half way between the MIN and MAX level. I thought the low oil light would have come on if the oil level dropped to MIN or below the MIN level?
Anyway, the oil is now topped up to the MAX level.
kam05
12-06-2017, 04:50 AM #12
12-06-2017, 04:55 AM
I'm suprised it came on if the oil level was that "high". I presume the car was on level ground when you checked it ? There's always a possibility that there was a problem with the sensor and the light came on incorrectly, but I guess you'll now know what to check if it does come on again !
12-06-2017, 04:55 AM #13
kam05
12-06-2017, 05:20 AM
Yep, the car was on level ground when I checked the oil level and also the engine was cold.
kam05
12-06-2017, 05:20 AM #14
Views 735
18-10-2022, 07:23 AM
Views 938
25-06-2022, 02:02 PM
Views 545
14-03-2022, 09:04 AM
Last Post by TezzaJoe
Views 1,026
14-01-2022, 10:27 AM
Last Post by lex2oos
Views 388
07-10-2021, 07:35 AM
Last Post by Stoney
Views 560
16-09-2021, 02:09 PM
Views 689
30-07-2021, 06:24 AM
Last Post by Dinho
Views 593
29-03-2021, 04:28 AM
Last Post by James S
Views 906
10-03-2021, 05:05 PM
Views 474
10-03-2021, 02:04 PM
Last Post by Colin G
