JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza wiring info needed
wiring info needed
wiring info needed
24-05-2018, 05:21 AM
also the relay that i was told to fit into the alarm ecu?
24-05-2018, 05:21 AM #11
24-05-2018, 10:23 AM
well i found this and can anybody tell me if this looks right
http://www.the12volt.com/installbay/foru...krayzie2k3
24-05-2018, 10:23 AM #12
24-05-2018, 10:42 AM
i think thats similar to how i have mine done....
i cant seem to find my paper work now......
24-05-2018, 10:42 AM #13
24-05-2018, 10:46 AM
Ignition output from turbo timer to 86.
Diode from 86 to 87a with band towards 86.
Key side of cut wire to 87a.
12volt + constant supply, fused at 30amps to 87.
Ground (earth) to 85.
Other (IGN) side of cut wire to 30.
24-05-2018, 10:46 AM #14
24-05-2018, 11:38 AM
sparkstav came back with this wire to cut to make is still lock and charge the battery
you need to attach a relay in the "ECU-IG" wire (Connection 10, plug A) brown/red wire.
You also need a 5 pin relay as your breaking the wire when turned on.
You need to connect the coil to earth and to one of the ign lives on the turbo timer harness, with a diode in the line of the same ign live to stop it feeding back.
The the wire from the ecu needs to be cut and go through the NC contacts of the relay.
24-05-2018, 11:38 AM #15
24-05-2018, 01:12 PM
A quick diagram using my excellent Paint skills:
[Image: Turbotimer.jpg]
The relay connection must be in the same one as the diode, but that can be either blue or green
So basically when you turbo timer turns on it basically turns power on to the blue and green cables, this will energise the relay making the Theft ecu think the car is off so you can lock it by remote.
The diode is there because otherwise when the car is on, the voltage will back feed and have the relay energised all the time.Which while isnt terrible its a good idea to put the diode in.
Edited 05-07-2011, 10:56 PM by Sparkystav.
24-05-2018, 01:12 PM #16
24-05-2018, 01:14 PM
cool man, thats looking better, i will do a write up of this one i think as i was a bit lost finding out what was needed.
24-05-2018, 01:14 PM #17
Views 303
01-11-2021, 11:52 AM
Views 315
12-06-2021, 09:38 AM
Views 167
25-12-2020, 10:57 AM
Views 170
01-08-2020, 04:06 AM
Last Post by Connor376
Views 228
05-04-2020, 06:55 AM
Last Post by purplewitch
Views 659
02-04-2020, 12:06 PM
Last Post by is300_dino
Views 210
03-12-2019, 02:58 AM
Views 228
01-12-2019, 05:21 AM
Views 264
01-11-2019, 02:01 PM
Last Post by rigga
