JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Car sometime's won't start first time...any ideas?
05-07-2018, 03:43 AM
Run some snowfoam through the engine is my suggestion. Made my car a lot more willing to start first time (well up until i changed the injectors, now the car gags on fuel when I start)
05-07-2018, 03:43 AM #11
05-07-2018, 03:49 AM
What is this snowfoam you speak of? Only time I've seen snowfoam it was that stuff for cleaning the outside of cars with?
05-07-2018, 03:49 AM #12
05-07-2018, 04:02 AM
You mean sea foam jim?
05-07-2018, 04:02 AM #13
05-07-2018, 04:04 AM
sprinter2012 What is this snowfoam you speak of? Only time I've seen snowfoam it was that stuff for cleaning the outside of cars with?
whoops (obsessed with cleaning). Sea foam is what I mean:
http://www.ebay.co.uk/itm/Seafoam-Inject...336a1d188c
Its not just 'another' injector cleaner though. Its some really good stuff. Basically you dump half in the fuel tank, and the other half you get the car to 'inhale' through a vacuum source.
EDIT:
Dark Samurai You mean sea foam jim?
well corrected Smile
Edited 16-08-2011, 01:40 PM by jimxms.
05-07-2018, 04:04 AM #14
EDIT:
05-07-2018, 04:18 AM
None in the oil, Jim?
05-07-2018, 04:18 AM #15
05-07-2018, 04:26 AM
Dark Samurai None in the oil, Jim?
Nah I'd deffo avoid doing the oil. For one, you need to change the oil after doing it. And for two, we've got old(ish) cars, some of which might well be held together with crusty old oil deposits.
05-07-2018, 04:26 AM #16
05-07-2018, 06:15 AM
Just ordered a tin, will update on any changes when I've run it through.
What vacuum source did you tip it in?
05-07-2018, 06:15 AM #17
05-07-2018, 06:57 AM
sprinter2012 Just ordered a tin, will update on any changes when I've run it through.
iirc I disconnected the one that goes to the power steering. Basically put half if the seafoam in a cup and let the engine sip at it slowly through the vacuum. Don't let it guzzle it or the car will stall. Once it's drank it all, switch off the car, empty the rest into the gas tank, And let the car sit for about 30 mins.
When you start the car up again be prepared to put your whole street under a thick cloud of smoke.
05-07-2018, 06:57 AM #18
06-07-2018, 01:48 AM
Would it be easier to just put half of it into a spray bottle, and just spray it into straight into the intake as a mist?
Or is it better to put it in a vaccum line?
06-07-2018, 01:48 AM #19
06-07-2018, 02:31 AM
sprinter2012 Would it be easier to just put half of it into a spray bottle, and just spray it into straight into the intake as a mist?
I would go vaccum personally - purely because I'd imagine there to be less for the fluid to cling to on its way into the engine (inside of the intake, throttle butterfly,...etc).
Its also probably quicker. It'll suck up the contents in about 30 seconds, even sipping it.
06-07-2018, 02:31 AM #20
Views 402
04-08-2019, 10:02 AM
Last Post by sprinter2012
Views 737
23-07-2019, 06:57 AM
Views 882
20-06-2019, 03:53 PM
Last Post by Mr Reman
Views 448
08-05-2019, 01:20 AM
Last Post by jomo
Replies 27
Views 1,617
02-05-2019, 12:59 AM
Views 760
23-01-2019, 12:22 PM
Last Post by reco2k
Replies 26
Views 1,431
09-09-2018, 07:16 AM
Last Post by Stoney
Views 821
07-09-2018, 12:41 PM
Last Post by clossie
Views 781
12-07-2018, 05:26 AM
Views 295
04-07-2018, 09:46 AM
