JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Gearbox Oil Change
Gearbox Oil Change
Gearbox Oil Change
05-11-2018, 07:56 AM
I put Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil in mine. Just because they had an offer on that brand at the time, but it does seem like some pretty good stuff, and you can use the same oil in the LSD too.
Got Fuchs Titan Race engine oil too.
Edited 17-12-2011, 05:31 PM by sprinter2012.
05-11-2018, 07:56 AM #11
05-11-2018, 07:58 AM
I have the fuchs engine oil and was looking at putting the fuchs stuff in, don't have an lsd on mine though Confusedad:
05-11-2018, 07:58 AM #12
05-11-2018, 08:03 AM
Well it's not just for LSD's, but that particular gear oil is Torsen LSD safe. Because you can't put normal LSD oil in the Torsen because it screws it up internally somehow.
05-11-2018, 08:03 AM #13
05-11-2018, 08:11 AM
2tongues Manual or Auto?
Manual 'box shouldn't ever need changing.
All Toyota service schedules include changing the gearbox oil, even a Yaris I had in!
Manual box takes 1.8 litres of GL-3 75W90, see http://bahamutcars.free.fr/workshop/IS_9...t_0008.pdf
Diff takes GL-5 SAE90 unless you live somewhere where you intend to use the diff below -18 degrees in which case it takes 80W90.
Open diff takes 1.05 litres, LSD takes 1 litre. See section 15 of http://bahamutcars.free.fr/workshop/IS_9...a_0065.pdf
Edited 17-12-2011, 05:53 PM by toxo.
05-11-2018, 08:11 AM #14
05-11-2018, 08:28 AM
So its a must job then Toxo
05-11-2018, 08:28 AM #15
05-11-2018, 08:33 AM
If that's what the book says then yes do it at the correct time for the vehicle.
05-11-2018, 08:33 AM #16
05-11-2018, 08:36 AM
Ight I will check tonight and see what the service book says
05-11-2018, 08:36 AM #17
05-11-2018, 08:38 AM
Lexuspat Ight I will check tonight and see what the service book says
It's right at the end of the list under 'miscellaneous' I think
05-11-2018, 08:38 AM #18
05-11-2018, 08:42 AM
Cheers gents I'm guessing its the standard thing when replacing the oil,
Undo filler plug
Undo drain plug
Top up X amount
05-11-2018, 08:42 AM #19
Undo filler plug
Undo drain plug
Top up X amount
05-11-2018, 08:45 AM
Lexuspat Cheers gents I'm guessing its the standard thing when replacing the oil,
Undo filler plug
Undo drain plug
Top up X amount
Yep, you let it all drain out completely, put the bottom plug back in. And then fill it back up through the one on the side untill it fills up to the level of the hole, then put the side plug back in. Job done.
05-11-2018, 08:45 AM #20
Undo filler plug
Undo drain plug
Top up X amount
Views 237
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 280
29-08-2020, 11:41 AM
Last Post by Connor376
Views 473
01-09-2019, 03:22 PM
Last Post by JayJay1374
Views 345
02-09-2018, 11:45 AM
Views 443
24-06-2018, 03:24 AM
Last Post by Biglee 22
Views 502
18-01-2018, 10:44 AM
Views 461
02-06-2017, 10:54 PM
Last Post by TM
Views 455
23-12-2016, 09:40 AM
Views 434
02-11-2016, 10:07 AM
Last Post by aaronabbott
Views 711
16-07-2016, 11:16 PM
Last Post by kam05
