JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Illuminated door handles?
12-11-2018, 04:21 AM
ok what you need to do
Place the negative cable of the LED strip on the negative of the battery
Place the positive of the Multimeter on positive of the battery
place negative of multimeter to positive of led strip
with multimeter set to amps turn it on and voilà the strip should illuminate and you will have a reading on the multimeter this is the reading in amps etc.....
hope that helps
12-11-2018, 04:21 AM #11
hope that helps
jomo
12-11-2018, 04:28 AM
Ok mate cheers., ill give it a go.
How do i find out what's the max i can draw from the ign light wire, without setting my car alight!
Cheers.
jomo
12-11-2018, 04:28 AM #12
Cheers.
12-11-2018, 04:30 AM
you will need to see what fuse rating is on the ign circuit at a guess 10amps......
12-11-2018, 04:30 AM #13
jomo
12-11-2018, 04:37 AM
Doh, right stupid me lol.
Cheers for the help rab.
jomo
12-11-2018, 04:37 AM #14
12-11-2018, 04:38 AM
no problem mate thats what the club is here for to help members out Smile
12-11-2018, 04:38 AM #15
12-11-2018, 05:05 AM
jomo Ok mate cheers., ill give it a go.
Cheers.
Trust me, you won't overload it with LED's.
I had a 7" LCD screen, a 12v netbook charger, and a satnav all running off my cigarette lighter at times and nothing got warm. Although I wouldn't want to do that too often.
I ran a strip of those 24 LED's off a power supply at work, which allows it to just take as much power as it needs, and then shows you on a digital readout. I can't remember the numbers but it's seriously nothing to get worried about. You'd need literally thousands of those LEDs before anything blew.
12-11-2018, 05:05 AM #16
Cheers.
jomo
12-11-2018, 07:37 AM
sprinter2012 Trust me, you won't overload it with LED's.
Thousands!!!! dont tempt me Sprinter!!! lol.
That go to know as i was thinking of putting pudle lights on the rear doors from the front door red marker light.
jomo
12-11-2018, 07:37 AM #17
12-11-2018, 07:42 AM
Thousands of LEDS can be soo much fun.......
12-11-2018, 07:42 AM #18
12-11-2018, 08:13 AM
I can understand the logic in illuminating underneath the exterior door handles when you unlock the car. Interior door handle lights are a bit drug dealerish Big Grin
A t5 SMD would fit the bill, really small and puts out a lot of light.
12-11-2018, 08:13 AM #19
jomo
12-11-2018, 09:15 AM
Had a look at the handle today, not too sure where a single led would fit, my go down the road of a strip of 3 with 3m tape on the back, also need to find a neet way to run a wire into the door from the car!
jomo
12-11-2018, 09:15 AM #20
 4 Guest(s)
 4 Guest(s)
Views 178
23-01-2021, 07:58 AM
Views 281
30-03-2019, 11:33 AM
Last Post by posty
Views 491
24-11-2018, 04:03 AM
Views 554
06-04-2018, 10:24 AM
Views 1,228
25-01-2018, 03:28 PM
Last Post by is300_dino
Views 570
05-01-2018, 10:57 AM
Views 372
26-11-2017, 01:06 PM
Views 461
25-09-2017, 12:28 AM
Replies 18
Views 694
15-04-2017, 11:41 AM
Last Post by Bandit
