Pages (135): Previous 119 20 21 22 23135 Next
Jimbob-T-Lex
Moderator
1,674
07-10-2019, 09:24 AM
wonder if someone can help what is the best spark plugs to use with the turbo setup i see all these grades and i remember a lil debate going on just cant find the thread?
Jimbob-T-Lex
07-10-2019, 09:24 AM #201
S
07-10-2019, 11:34 AM
how much boost?
S
07-10-2019, 11:34 AM #202
how much boost?
S
07-10-2019, 11:41 AM
Here you are:
http://www.outlawjapclub.co.uk/forum/sho...post198899
Jimbob-T-Lex
Moderator
1,674
07-10-2019, 12:14 PM
not sure what boost but gonna be aiming for 350bhp min mate thanks for the link Wink
Jimbob-T-Lex
07-10-2019, 12:14 PM #204
07-10-2019, 02:59 PM
Just get the same as me, a grade colder thank standard, not expensive, and work.
07-10-2019, 02:59 PM #205
Jimbob-T-Lex
Moderator
1,674
25-10-2019, 05:56 PM
Right a little update!
I bought a few odds and sods like the sports pedals and door sills they should be delivered sometime this week
Paid deposit on my manifold and downpipe (Many Thanks IKE)
Reverse dip mirrors module
Cant remember what ive actually got getting delivered
Still not got hold of the injectors but money holding me back at present need pay day to come!!!
Next updates will be the actual build and loads of photos will be uploaded maybe few vids take care all!!
Edited 06-12-2012, 03:32 AM by Jimbob-T-Lex.
Jimbob-T-Lex
25-10-2019, 05:56 PM #206
Jimbob-T-Lex
Moderator
1,674
02-11-2019, 03:04 PM
Right a little update went to fit the head studs today and hit a problem straight away i didnt realise that the ARP studs from the surpra had to be the mains ones for the head on the 1GFE engine so i got another set order and they will be on there way tomorrow!
Also today checked the block over as its been 5 months since ive seen it so give it the once over and scraped any old gasket or muck off the top and bottom, also cleaned my threads out.
Tomorrow i will be fitting the mains ARP studs and bearing so the crank shaft can be installed.
After this i will get the pistons in with the new bearings and rings and start on a few ancillaries.
Ill get lots of photos so watch this space not the best of starts i know but its never plain sailing lmao
Jimbob-T-Lex
02-11-2019, 03:04 PM #207
Jimbob-T-Lex
Moderator
1,674
05-11-2019, 09:53 AM
right what ive got done so far:
Fitted my new door sills
Started on my 3x pod for gauges
[Image: IMG_0972_zpsce2fa3ac.jpg]
[Image: IMG_0973_zps740f8a73.jpg]
Fitted the new bearing and crankshaft with the ARP studs (for anyone wanting to do this is is a 12 point 12mm socket that is required)
[Image: IMG_1128_zps75944a4b.jpg]
[Image: IMG_1130_zpsb2d5d6ed.jpg]
[Image: IMG_1132_zpsfc28cf0f.jpg]
[Image: IMG_1131_zps6f4d9c47.jpg]
Got pistons going in but a big boo boo ring compressor broke and so did a piston ring so ordered a new set and a bit better compressor i stayed very calm honest!!!
started fitting the timing belt casing and the rearoil seal retainer
All have new gaskets and seals
Next couple of days im going to fit these:
Oil strainer
Oil cooler
Knock sensors
Oil dipstick guide support
Water outlet pipe
Jimbob-T-Lex
05-11-2019, 09:53 AM #208
Oil strainer
Oil cooler
Knock sensors
Water outlet pipe
05-11-2019, 10:27 AM
Keep the pictures coming mate!
05-11-2019, 10:27 AM #209
Jimbob-T-Lex
Moderator
1,674
05-11-2019, 10:36 AM
Will do mate!
Jimbob-T-Lex
05-11-2019, 10:36 AM #210
Will do mate!
 5 Guest(s)
 5 Guest(s)
Views 5,120
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,746
25-03-2024, 02:10 AM
Views 9,079
23-03-2024, 03:45 PM
Views 20,284
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,483
08-10-2023, 03:59 AM
Views 5,976
06-10-2023, 02:58 AM
Views 3,125
04-10-2023, 03:52 PM
Replies 76
Views 2,790
30-09-2023, 01:24 AM
Last Post by RichS11
