Pages (135): Previous 124 25 26 27 28135 Next
22-11-2019, 11:40 PM
jimbob150385 let me know what u want i think you got my address if not drop me a pm mate
Oh on the intercooler mate how did you mount the top did you just make up some brackets not looked behind the bumper too much?
Yeah I've still got one of the brackets at home for the intercooler, the other broke on removal.
They are just little brackets in a step shape to below the bottom mount rad mount area.
22-11-2019, 11:40 PM #251
Jimbob-T-Lex
Moderator
1,674
23-11-2019, 02:54 AM
ok mate thanks ill have a gd look when i get the lump out
Jimbob-T-Lex
23-11-2019, 02:54 AM #252
Jimbob-T-Lex
Moderator
1,674
24-11-2019, 05:34 AM
Pistons rings, piston ring compressor and head locating bushes all delivered today so can crack with these bits tomorrow also had an email of IKE turbo kit not arriving till tuesday now ill get pics tomorrow of the new rings fitted and piston install
Jimbob-T-Lex
24-11-2019, 05:34 AM #253
Jimbob-T-Lex
Moderator
1,674
24-11-2019, 07:29 AM
A little question for ppl when wiring in the greddy did ppl wire in at the actual plugs of the ecu or just tap in to the ecu loom that run along the engine bay? might get this started as its gonna be one of the lengthy jobs
Jimbob-T-Lex
24-11-2019, 07:29 AM #254
S
24-11-2019, 09:09 AM
Just tap into the standard loom it will be 1million times easier, if not the only way.
S
24-11-2019, 09:09 AM #255
Jimbob-T-Lex
Moderator
1,674
24-11-2019, 09:12 AM
i wasnt sure where to tap in to the loom half way up in the engine bay or at the plug end of the standard ecu at the front of the engine bay buy the ecu case because if i do the second i will have to extend the 1.5m universal harness i have got
Jimbob-T-Lex
24-11-2019, 09:12 AM #256
24-11-2019, 09:18 AM
You will have to extend the wiring loom mate, it's by far the easiest way to tap in by the plugs so you can find the wires.
Most of the engine loom comes out and immediately to the engine from the ecu box so tapping into the loom on the Wong wont work.
24-11-2019, 09:18 AM #257
Jimbob-T-Lex
Moderator
1,674
24-11-2019, 09:21 AM
Ok brill mate thought i would have to just means i can crack on with that thanks
Jimbob-T-Lex
24-11-2019, 09:21 AM #258
mattlaw
24-11-2019, 10:01 AM
Glad to here those bushes got there, are they the right ones?
mattlaw
24-11-2019, 10:01 AM #259
Jimbob-T-Lex
Moderator
1,674
24-11-2019, 10:34 AM
i aint tried them yet mate ill let you know tomorrow look the right ones
Jimbob-T-Lex
24-11-2019, 10:34 AM #260
 6 Guest(s)
 6 Guest(s)
Views 5,121
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,794
25-03-2024, 02:10 AM
Views 9,080
23-03-2024, 03:45 PM
Views 20,343
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,483
08-10-2023, 03:59 AM
Views 5,988
06-10-2023, 02:58 AM
Views 3,135
04-10-2023, 03:52 PM
Replies 76
Views 2,796
30-09-2023, 01:24 AM
Last Post by RichS11
