JapCarForum Cars, Cars, Cars! Project Cars Lexus Is200 SE Project
Pages (28): Previous 124 25 26 27 28 Next
ZAIS200
10-04-2020, 09:45 PM
Good question, I'd like to know too, need to be looking for the right uprated injectors too, trying to decide which ones would be best as i want to try get injectors that need little or no modifications, I've heard the 1JZ or 2JZ injectors fit the fine but i'm unsure if they fit the loom right read this off one of the australian forums somewhere...
ZAIS200
10-04-2020, 09:45 PM #261
phaebo
10-04-2020, 11:07 PM
The 1zzfe green injectors are 250cc and with new is200 rubber o-rings they are a straight fit. No modifications needed. They wiring is direct fit
phaebo
10-04-2020, 11:07 PM #262
john wan
10-04-2020, 11:34 PM
Oooooo sweet ill be looking for them are they standard on corrola or celica?
john wan
10-04-2020, 11:34 PM #263
ZAIS200
10-04-2020, 11:41 PM
Ok and will these be fine for a mild turbo conversion or would it be better to go slightly higher?
What i mean is i'm looking to get between 250 and 300 hp (at the flywheel of course) using a GT28 or a TDO4 turbo, will the 1ZZ injectors be sufficient or should i go for an injector rated above 300CC? and a higher rated fuel pump?
ZAIS200
10-04-2020, 11:41 PM #264
S
10-04-2020, 11:47 PM
phaebo Thanks for the replies.
@ste176
The stuttering is probably caused by the small injectors. My car used to stutter a little bit under 2000rpm with foot down. But now i have bigger injectors green 1zzfe injectors the car doesnt stutter anymore.
Still running the blackbox from patrick.
I can imagine that the stutter will be more with a bigger pulley because more air in the inlet causes a leaner air fuel ratio
The car stutters regardless of pulley size, we think it's too much load on the throttle body motor.
S
10-04-2020, 11:47 PM #265
@ste176
S
10-04-2020, 11:49 PM
ZAIS200 Ok and will these be fine for a mild turbo conversion or would it be better to go slightly higher?
1zz should be fine, but bigger is always better.
You should definitely fit a bigger pump, fpr and fuel return line.
S
10-04-2020, 11:49 PM #266
ZAIS200
10-04-2020, 11:52 PM
Ok thanks for the reply Stix, is there any truth to the 1JZ/2JZ injectors being compatible?
ZAIS200
10-04-2020, 11:52 PM #267
S
10-04-2020, 11:53 PM
ZAIS200 Ok thanks for the reply Stix, is there any truth to the 1JZ/2JZ injectors being compatible?
I've honestly no idea, mine are 650cc from a Subaru!
S
10-04-2020, 11:53 PM #268
ZAIS200
11-04-2020, 12:04 AM
hmmmm and are those a straight swap?
or did you need to modify the loom or the head?
ZAIS200
11-04-2020, 12:04 AM #269
S
11-04-2020, 12:07 AM
ZAIS200 hmmmm and are those a straight swap?
I had to change the plugs, but mine were brand new and came with new plugs so it wasn't a problem.
S
11-04-2020, 12:07 AM #270
 4 Guest(s)
 4 Guest(s)
Views 5,124
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 1,531
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 102,865
25-03-2024, 02:10 AM
Views 9,083
23-03-2024, 03:45 PM
Views 20,370
18-02-2024, 11:42 PM
Views 67,983
08-02-2024, 01:53 AM
Views 404
18-12-2023, 02:55 AM
Views 1,485
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
