Pages (132): Previous 1 … 25 26 27 28 29 … 132 Next
19-10-2017, 10:21 AM
The 1G-FE does have a variable length inlet manifold too though. It's plastic, and has a valve which is initially closed but opens at a certain point to lengthen the inlet tract. T-VIS sounds very similar.
This is the part which Almost Finished has changed on his car, because it was a limiting factor. But then he's pushing much higher bhp levels than me.
19-10-2017, 10:21 AM #261
19-10-2017, 10:29 AM
Ah OK - I'd expect ACIS rather than T-VIS but they are very similar. Toyota did away with it in later MR2 engines because it was unreliable and didn't help the power curve at all. I presume they have improved it since!
19-10-2017, 10:29 AM #262
19-10-2017, 10:31 AM
Yep, ACIS is exactly what it is (Acoustic Control Induction System).
19-10-2017, 10:31 AM #263
19-10-2017, 10:39 AM
So anyway, back to my original point which is that it doesn't really serve a useful purpose on FI engines Smile Toyota themselves removed it from their later turboed engines!
Out of interest, how well is a plastic inlet manifold going to cope with turbo intake temps? I would presume it won't be that big of a deal and that Charlesworth will have a much better idea about the effects than me Smile but if you were to heatsoak your intercooler up to 70+ degrees it might not be too happy Big Grin Plus isn't it bolted directly to the head which will be a much hotter place with FI than N/A... or does the ACIS valve act as a phenolic gasket?
Edit: Sorry if I sound like I'm trying to find holes in your plan - I'm not, I'm just very interested in the build!!
Edited 30-11-2009, 02:31 PM by toxo.
19-10-2017, 10:39 AM #264
19-10-2017, 10:45 AM
I don't know what a phenolic gasket is Big Grin but Charlesworth don't think it's going to be a problem. As you mention, I've got an intercooler so I can't imagine the air going through the intake manifold is going to be that hot, otherwise I'm going to have a big problem anyway !
19-10-2017, 10:45 AM #265
19-10-2017, 10:50 AM
Phenolic gasket is an insulating gasket to stop the heat generated from combustion from heating up the inlet manifold in an attempt to lower intake temperatures a bit more.
I shall let you know if I have any more questions Smile I have suffered terribly from heatsoak with my intercooler, that's why I got rid of it and went for chargecooling instead. But a bay with a 3S-GTE in it is a VERY hot place so you shouldn't suffer too bad!
19-10-2017, 10:50 AM #266
19-10-2017, 10:51 AM
I've just been trying to find out the part numbers of the electrical connector for the fuel injectors for an Altezza SXE10 (i.e. with 4-cylinder 3S-GE), since this is the car those injectors are designed to plug straight into - so presumably it has the connectors I need. This is only a fallback, I'm still hopeful that the existing connectors from the 1G-GTE donor engine will work too.
I've found the part number for a 1G-FE but can't find it for a GTE. (can't find it on Toyodiy).
I spoke to Lexus/Toyota but they wanted the frame code for the car to be able to progress it. This is the Japanese equivalent of a VIN. Now I don't have one of course, since I don't have a Tezza ! But I did a bit of Googling, found a suitable frame code and gave it to Lexus/Toyota and am waiting for them to get back to me !
19-10-2017, 10:51 AM #267
19-10-2017, 10:56 AM
Sneaky, but if it works!!
19-10-2017, 10:56 AM #268
19-10-2017, 10:59 AM
toxo Phenolic gasket is an insulating gasket to stop the heat generated from combustion from heating up the inlet manifold in an attempt to lower intake temperatures a bit more.
Cool, all input is much appreciated ! :thumbup:
19-10-2017, 10:59 AM #269
19-10-2017, 11:03 AM
Good luck with getting the electrical connectors, even my Toyota parts guy struggles with those. There used to be *3* books required to look up *1* connector (from its silhouette), and since they went completely digital with their parts catalogue that information is very hard to find.
19-10-2017, 11:03 AM #270
Views 15,300
Views 4,184
Views 5,131
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 181,150
Views 23,723
Views 49,466
Views 147,719
Views 1,391
Views 4,026
Views 6,970
