Pages (135): Previous 126 27 28 29 30135 Next
Jimbob-T-Lex
Moderator
1,674
29-11-2019, 01:11 AM
messaged you the part numbers matt thanks
Jimbob-T-Lex
29-11-2019, 01:11 AM #271
mattlaw
29-11-2019, 09:40 AM
Sorry for the the bad news mate
mattlaw
29-11-2019, 09:40 AM #272
Jimbob-T-Lex
Moderator
1,674
29-11-2019, 09:43 AM
not to worry mate i found prius rings with the same bore and top ring size but been looking at whether i could use a second ring as a top compression ring and it a no go so gonna have to order 2 sets of prius rings pain but such as life
Jimbob-T-Lex
29-11-2019, 09:43 AM #273
Jimbob-T-Lex
Moderator
1,674
01-12-2019, 07:15 AM
Right im gonna hook up the greddy tomorrow but i obviously dont want it to interfere as the turbo lump is not on can i just hook up but leave the ign on cable disconnected or can i hook it all up but just have all the switches set to off on the front (obviously i wont cut the cables that need to before i get the turbo lump in) just trying to save time later on??
Jimbob-T-Lex
01-12-2019, 07:15 AM #274
01-12-2019, 09:28 AM
Hook it up. You'll need to have power to it or nothing will work.
Set everything on it to zero. But you'll need the correct engine settings programmed in.
01-12-2019, 09:28 AM #275
Jimbob-T-Lex
Moderator
1,674
01-12-2019, 11:43 PM
do you once it is wired in go to the settings on the laptop and set all to zero? I was having a look at the programme and you can select 1gfe as the vehicle will this not put the engine settings on mate?
Ive still got to use the car for work at the minute so dont want to have her not working as using my dads soarer todo 80miles a day is gonna kill me lol
Jimbob-T-Lex
01-12-2019, 11:43 PM #276
Jimbob-T-Lex
Moderator
1,674
02-12-2019, 01:34 AM
Think ive worked it out mate by reading about! one thing i dont get when i looked over the greddy install write up they have a map sensor installed inside from the throttle body i know its the absolute pressure but dont the is200 have one or is it just that it doesnt have the correct range of measurement? im quite lost on map sensors lol im stabbing in the dark really thought is was to check the egr valve! pmsl
Jimbob-T-Lex
02-12-2019, 01:34 AM #277
02-12-2019, 02:18 AM
The is map sensor runs out of space about 0.5 bar I seem to remember. So you need a separate map sensor for anything over that.
02-12-2019, 02:18 AM #278
Jimbob-T-Lex
Moderator
1,674
02-12-2019, 04:37 AM
Ok mate well i havent got a map sensor yet can i just leave this wire or will this not work at all if i hook the rest up im not sure what the standard map pin out is on the ecu
Jimbob-T-Lex
02-12-2019, 04:37 AM #279
02-12-2019, 10:46 AM
Yeah you don't have to hook that up now but you'll need to eventually to stop fuel cut.
02-12-2019, 10:46 AM #280
 4 Guest(s)
 4 Guest(s)
Views 5,121
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,818
25-03-2024, 02:10 AM
Views 9,080
23-03-2024, 03:45 PM
Views 20,347
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,483
08-10-2023, 03:59 AM
Views 5,994
06-10-2023, 02:58 AM
Views 3,135
04-10-2023, 03:52 PM
Replies 76
Views 2,799
30-09-2023, 01:24 AM
Last Post by RichS11
