JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Gearbox Oil Change
Gearbox Oil Change
Gearbox Oil Change
Pages (3): Previous 1 2 3
05-11-2018, 08:47 AM
Yep done it many times on other cars but this is a lexus after all and some things they don't make easy :laugh:
Edited 17-12-2011, 06:24 PM by Lexuspat.
05-11-2018, 08:47 AM #21
05-11-2018, 08:51 AM
The key is to remember to remove the filler plug first before you drain the oil out. And as per quite a few cars, the refill process is to fill it up until it overflows - gearbox oil is nasty stuff so make sure you catch / clean up any overspill. And obviously the car has to be level when you fill it!
05-11-2018, 08:51 AM #22
05-11-2018, 09:11 AM
Luckily I have a motor club available to me with ramps and spill sorb, I only recently did a mates car that's what made me think of it to be honest
05-11-2018, 09:11 AM #23
Talisker
06-11-2018, 02:17 AM
Just for info, i've used this method before for filling the gearbox. The last time was recently when i replaced my clutch, I changed the oil when the gearbox was on the bench - so much easier.
I put a drip tray under the gearbox (very important). I undid the fill plug and ran a length of tube from the gearbox up into the engine bay next to the exhaust manifold. Wedged a funnel into the end of the tube then filled to spill.
Yeah, it makes a bit of a mess but it's easier than having the car on axle stands and messing about under the gearbox with odd shaped bottles and inflexible spouts.
Of course if i had a pump i'd use that instead :tongue_smilie:.
Talisker
06-11-2018, 02:17 AM #24
06-11-2018, 02:28 AM
Most 1ltr bottles now have the tube inside so u can pour it in without messing around to much, or at least the ones I have purchased lately
06-11-2018, 02:28 AM #25
Talisker
06-11-2018, 11:09 AM
True, the last lot of oil I got had integral tubes, but the one before that didn't for some reason. But like i said, I did the last oil change while the transmission was off and sitting on the bench.
That is truely the easiest way of doing an oil change......if you don't mind the hassle of taking the transmission off :biggrin:
Talisker
06-11-2018, 11:09 AM #26
rob
16-11-2018, 10:13 PM
Lexuspat Most 1ltr bottles now have the tube inside so u can pour it in without messing around to much, or at least the ones I have purchased lately
you wont get the tube anywhere near the fill port.
either do as suggested with a length of tube - still a total PITA or get a fluid pump and an extra bottle of oil.
same goes for the rear diff... get about 1.5m of 12mm ID tube and a funnel.
drain the fluid, feed the tube in from the wheel arch and into the diff and then fill.
trust me its less hassle.
rob
16-11-2018, 10:13 PM #27
18-11-2018, 11:35 PM
Cheers rob will see what its like when I do it, thanks for the advice on this will have a go at doing one of these days
18-11-2018, 11:35 PM #28
rob
19-11-2018, 06:19 AM
you will need a 24mm spanner also BTW for the drain/fill plugs
rob
19-11-2018, 06:19 AM #29
 5 Guest(s)
 5 Guest(s)
Views 237
28-01-2021, 10:36 AM
Last Post by 1374lee
Views 280
29-08-2020, 11:41 AM
Last Post by Connor376
Views 473
01-09-2019, 03:22 PM
Last Post by JayJay1374
Views 345
02-09-2018, 11:45 AM
Views 443
24-06-2018, 03:24 AM
Last Post by Biglee 22
Views 502
18-01-2018, 10:44 AM
Views 461
02-06-2017, 10:54 PM
Last Post by TM
Views 455
23-12-2016, 09:40 AM
Views 434
02-11-2016, 10:07 AM
Last Post by aaronabbott
Views 711
16-07-2016, 11:16 PM
Last Post by kam05
