JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Illuminated door handles?
12-11-2018, 09:20 AM
can't you run a line up from the red light in the bottom corner of the door card? I think they already come on as desired anyway.
12-11-2018, 09:20 AM #21
i did look into this when i had mine ill see if i can find the pictures of the handle to decibe its location lol
12-11-2018, 09:20 AM #22
12-11-2018, 09:21 AM
el_bandido can't you run a line up from the red light in the bottom corner of the door card? I think they already come on as desired anyway.
you could be right but the rear doors dont have any light in them or do they and i never noticed lol....
12-11-2018, 09:21 AM #23
jomo
12-11-2018, 09:24 AM
The red door marker lights only come one when you open the door, not when you un-lock it.
Need to run a feed from the ign barrel lighting ring.
jomo
12-11-2018, 09:24 AM #24
12-11-2018, 09:35 AM
here is a similar mod on a later spec is but you can see the single led mod thats done
http://my.is/forums/f221/diy-led-back-li...es-392385/
12-11-2018, 09:35 AM #25
jameshunter
12-11-2018, 10:14 AM
this might help with the idear of the door handle light ,I am also going to be doing this with my is200
jameshunter
12-11-2018, 10:14 AM #26
jameshunter
12-11-2018, 10:16 AM
**** lol didnot notace the post above my bad
jameshunter
12-11-2018, 10:16 AM #27
12-11-2018, 10:55 AM
its easier if you buy 12v LEDs rather than standard ones that need the power reducing etc....
12-11-2018, 10:55 AM #28
jomo Thousands!!!! dont tempt me Sprinter!!! lol.
That go to know as i was thinking of putting pudle lights on the rear doors from the front door red marker light.
haha, even if you put LEDs on every handle, under every door, in the boot, under the bonnet, you'd never have enough to blow a fuse.
But I'd be wary of using them in too many locations at the risk of turning your car into a christmas tree when you unlock it. :lol:
12-11-2018, 10:55 AM #29
12-11-2018, 10:58 AM
when you do decide to do this make sure you make a walkthrough as it will help others the club can make it a general sticky afterwards
12-11-2018, 10:58 AM #30
 4 Guest(s)
 4 Guest(s)
Views 178
23-01-2021, 07:58 AM
Views 281
30-03-2019, 11:33 AM
Last Post by posty
Views 491
24-11-2018, 04:03 AM
Views 554
06-04-2018, 10:24 AM
Views 1,228
25-01-2018, 03:28 PM
Last Post by is300_dino
Views 570
05-01-2018, 10:57 AM
Views 372
26-11-2017, 01:06 PM
Views 461
25-09-2017, 12:28 AM
Replies 18
Views 694
15-04-2017, 11:41 AM
Last Post by Bandit
