JapCarForum Cars, Cars, Cars! Project Cars My IS-V8-Turbo
My IS-V8-Turbo
My IS-V8-Turbo
Pages (53): Previous 129 30 31 32 3353 Next
Marcus_1UZ
26-08-2016, 04:42 AM
Bandit Bet your dying to really open her up and see how it goes, or have you allready :w00t:
The funny thing is, when i took my boys out in it around town, i did try to open her up but the wastgate keeps opening to soon, " and im like why the f** is that opening that quick" so any way the last 2-3 days i was starting her up reving the nuts out of it and the wastgate opens at about 3000rpm, but i could not hear the BOV, so i start to play around with the vac/lines and it seem,s the one i had the BOV connected to is not working? ( well it works but not all that well) so i swap it over to one that i had caped of and now the wastgate dont open untill about 4500RPM and when i let go theres a nice big sound from the BOV now as well ( but dont forget i have no boost controller connected yet) so i can not hold the boost, but it should still be fun:tongue_smilie:
wastgate is set to open at 10psi
I have not taken it out yet to see what it is like, as for the past 3 days its been raining here....:crying:
Marcus_1UZ
26-08-2016, 04:42 AM #301
26-08-2016, 04:52 AM
Your going to be in for some serious fun when you do open it up :w00t:
If its anything like mine the rear will break traction in the wet or the dry and for some reason it gives you quite a big smile :laugh:
Got to have a look at my fueling as i/ve just done 16miles and it cost me £10 in fuel Confusedhock: Have a feeling its the silicone hoses i've fitted to the engine, as before it was ok, but since they have been on the fueling has gone terrible? so not sure if there too soft for vacuum lines and there closing up under pressure??
So might fit the oem set again to see if it makes a difference? cant see what else it could be as the rest is still the same as it was before? God help me when i turn up the boost Confusedcared:
26-08-2016, 04:52 AM #302
Marcus_1UZ
26-08-2016, 05:26 AM
Bandit Your going to be in for some serious fun when you do open it up :w00t:
yea im not a big fan of driveing in the rain, so try not to if i can help it:tongue_smilie: as i know with the V8 in the IS the IS will be all over the place lol,
wow thats not much miles for £10 i would put your old hose,s back on and see what you get then, like you say the hose,s could well be cloing up under boostConfusedhock:
Marcus_1UZ
26-08-2016, 05:26 AM #303
26-08-2016, 01:15 PM
Interesting that you're having problems with water pumps. Are you using original Toyota/Lexus pumps? We have had some guys doing engine swaps on MR2s and once you change the water system around it can put additional strain on the water pump (certainly in the MR2 there is further to pump the water, more water, etc). The pattern pumps people are fitting from motor factors are not up to the job. Admittedly this is with the 3.0 V6 engine.
Are you using the original radiator for the engine or is it a larger capacity/thicker? I assume with the turbo mounted directly next to the radiator the water temps are through the roof. I'd be putting SPAL fans on the radiator (you will probably create big problems with having the fan on the FRONT of the radiator as it causes an obstruction to natural airflow) and look at what temperature your thermostat is opening at. TRD thermostats open at lower temperatures which could be also useful in your situation, just to get things circulating quicker.
Edited 07-10-2009, 10:57 PM by toxo.
26-08-2016, 01:15 PM #304
Marcus_1UZ
26-08-2016, 10:53 PM
toxo Interesting that you're having problems with water pumps. Are you using original Toyota/Lexus pumps? We have had some guys doing engine swaps on MR2s and once you change the water system around it can put additional strain on the water pump (certainly in the MR2 there is further to pump the water, more water, etc). The pattern pumps people are fitting from motor factors are not up to the job. Admittedly this is with the 3.0 V6 engine.
Hi john, The thing is with the engine, it had been sitting for along time, and i should have replaced the pump to start with:mad: not only that i did not have it set up the same way as it use to be in the LS400, where as now i have put it back to the way it was before i pulled the engine from the LS400, and all seems to be ok, as for the fan thats the only place i have room for it, but i will be moveing the oilcooler to a new place and then i will fit a 2nd fan in its place, The same with the turbo it has to go there as on the IS200 there is not much room and thats the best place for it, i do have a heatshield round it now where as before i did not have one , I think the thermostat opens at around 70.oC the fan is not linked to it in any way i can turn it on & off when i likeWink so before i go any where i turn it on.
This weekend will be the 1st run it would of had, but then it looks nice today out so i may take it out today just to make sure all is 100% ok:biggrin:
Marcus_1UZ
26-08-2016, 10:53 PM #305
26-08-2016, 11:46 PM
OK. My point still stands about the water pumps you're using. These are 2 pumps for the 3VZ-FE:
[Image: 29062009268.jpg]
Note the difference in impeller design. Left hand one is blueprint (Toyota is the same) right hand one is QH.
Not all water pumps are created equal :thumbup1:
26-08-2016, 11:46 PM #306
Marcus_1UZ
27-08-2016, 12:15 AM
Hi mate, i have only just put the new pump in, so time will tell if its as good, but it did look the same as the old one so thats a good start.
toxo OK. My point still stands about the water pumps you're using. These are 2 pumps for the 3VZ-FE:
Marcus_1UZ
27-08-2016, 12:15 AM #307
27-08-2016, 12:42 AM
toxo [Image: 29062009268.jpg]
I'm just going by how they look here. The right hand one looks a lot stronger, but the left hand one seems to have *much* bigger vanes, and even though it has slightly less vanes than the one on the right, it looks like the one on the left would have a better flow ? I could be totally wrong of course.
27-08-2016, 12:42 AM #308
27-08-2016, 12:46 AM
You're pretty much bang on. Both work fine in a Camry but when you put them in an MR2 the one on the right doesn't flow enough due to the impellor design. QH don't see it as a problem because their pump works just fine in a Camry which is what it was designed for, but I would assume that the wheel is a semi-standard part that's used on a variety of pumps.
Of course you don't run into these problems if you buy genuine :thumbup1:
Thread hijack over Smile I hope the car goes well this weekend, don't wanna be stuck in a tunnel trying to get water back into it!! I've had to do that in Rouen in a friends car before...
27-08-2016, 12:46 AM #309
Marcus_1UZ
27-08-2016, 02:16 AM
toxo You're pretty much bang on. Both work fine in a Camry but when you put them in an MR2 the one on the right doesn't flow enough due to the impellor design. QH don't see it as a problem because their pump works just fine in a Camry which is what it was designed for, but I would assume that the wheel is a semi-standard part that's used on a variety of pumps.
:lol: i will let you know how it goes, im going to take it out for a run today as the sun is out:w00t::tongue_smilie:
Marcus_1UZ
27-08-2016, 02:16 AM #310
 6 Guest(s)
 6 Guest(s)
Views 67,678
08-02-2024, 01:53 AM
Replies 23
Views 1,429
04-01-2023, 03:30 PM
Last Post by aaron1991ellis
Replies 65
Views 4,907
21-12-2022, 09:37 AM
Last Post by jeffrosie
Replies 179
Views 13,976
17-12-2022, 10:34 AM
Last Post by phaebo
Replies 39
Views 3,910
13-12-2022, 01:00 PM
Last Post by N15_GTi
Replies 69
Views 12,925
25-11-2022, 04:48 AM
Views 3,400
30-07-2022, 06:45 PM
Last Post by Lexus RS200T
Replies 1,318
Views 86,385
05-06-2022, 08:23 AM
Last Post by sarah0
Views 3,722
11-11-2021, 01:10 AM
Views 2,130
20-06-2021, 04:50 AM
