Needing a new LCD TV advice needed
Do you think I should run any other cables ? Or is that all I would need ?
to be honest mate it all depends on the sources you want to feed into the tv if you know what TV you are using then i would copy all the connections to a remote location out the way somewhere
Possibly a TOS link if supported by the TV?
Ok I have been having a quick look about , what do you experts think of this ........
http://www.ebay.co.uk/itm/Samsung-UE46D6...4ab638d125
Also I have held back on buying cables , because I dont have a clue except I know I would need HDMI ones :confused::thumbdown:
My parents have a smaller version of this very one - it is STUNNING, the blacks are just that blacker then our Plasma screen to really make the difference. Don't get me wrong the blacks on our Plasma are very good, just not as good - if that makes sense?
That dose make sense in your world mate , thats all that matters :kiltsmilie:
Well from the list of inputs/outputs
[quote]
Input & Output
HDMI 4
USB 3
Component In (Y/Pb/Pr) 1
Composite In (AV) 1 (Common Use for Component Y)
Digital Audio Out (Optical) 1
PC In (D-sub) 1
CI Slot 1
Scart 1
RF In (Terrestrial/Cable Input) 1
RF In (Satelite Input) 1 Headphone 1
PC Audio In (Mini Jack) 1
DVI Audio In (Mini Jack) 1 (Common Use for PC Audio In)
Ethernet (LAN) 1
[\quote]
Id say 4 hdmi cable, 3 USB extensions, a digital out, a 3.5mm jack, aerial (standard), and rj45 Ethernet.
Can't see you ever using more than that.
This looking at TVs is making my head hurt :confused1:
I'm now looking at this , but not from this seller ...........
http://www.ebay.co.uk/itm/Samsung-UE46D6...4ab01f704f
What do yous think of this one ?
I've found it for £702 compared to £999.99 in comet , just need to persuade the boss now :Bazza:
toxo The optical/digital out is the TOSlink that Phil was talking about.
TBH I'd do 2 HDMI, 1 analogue video (probably component), ethernet,2 USB, and an analogue audio (DVI audio in I guess). You'd never use anything else in the forseeable future.
