JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Vacuum bypass valve
Vacuum bypass valve
Vacuum bypass valve
marko45
05-03-2021, 06:21 AM
#31
lexusdaydreaming it would be cool to see it when its on.
Yes cause i am not sure to understand everything. For my part, i have the complete original TTE supercharger, pipes and so on. But i just want to replace the actual bypass valve and the cable and use instead that vacuum bypass.
But i am not sure to understand where your custom mount and T piece go.
I thought the custom mount was a sort of spacer that would allow the Mini bypass with three bolts to be mounted on the original four bolts of the inlet of the supercharger. But i might be wrong.
marko45
05-03-2021, 06:21 AM #31
rob
05-03-2021, 06:35 AM
#32
marko45 When i meant full boost, i meant completely delivered for a given rpm and not partially as the TTE does.
Yes it does that.
rob
05-03-2021, 06:35 AM #32
Yes it does that.
196
05-03-2021, 09:48 AM
#33
to my understanding it the same as the tte one and it goes where the old one is. but as its flat on one side and needs 3 bolts to seal it shut you need to have a custom made t piece just as normal but on the spout where the new bypass goes it has to have a plate and 3 holes on the end of the spout for the bypass to be mounted.
lexusdaydreaming
05-03-2021, 09:48 AM #33
marko45
05-03-2021, 10:06 AM
#34
I really think pics would be great for a better understanding.
marko45
05-03-2021, 10:06 AM #34
196
05-03-2021, 11:54 AM
#35
i can draw what i am doing i wont have part till end of week. give me 5 mins all try sort something
lexusdaydreaming
05-03-2021, 11:54 AM #35
marko45
05-03-2021, 12:01 PM
#36
Ok i can wait 5 mins but not more lol...
marko45
05-03-2021, 12:01 PM #36
196
05-03-2021, 12:27 PM
#37
ok dont laugh at the drawing Smile but i hope it explains what i plan todo and if it wont work id like others to say but am sure its right.
http://i1375.photobucket.com/albums/ag44...05fa1b.jpg
lexusdaydreaming
05-03-2021, 12:27 PM #37
05-03-2021, 01:00 PM
#38
Makes sense to me
05-03-2021, 01:00 PM #38
Makes sense to me
05-03-2021, 01:11 PM
#39
Smile all be running my bypass pipe to before throttle somewhere for the cold air to go back to supercharger. it was phaebo that helped me there. and with most of my setup.
lexusdaydreaming
05-03-2021, 01:11 PM #39
marko45
05-03-2021, 10:44 PM
#40
I understand now what you meant by "T piece". I did not understand you would change the complète inlet pipe of the sc.
marko45
05-03-2021, 10:44 PM #40
Views 552
27-08-2023, 03:56 AM
Last Post by phaebo
Views 465
06-04-2023, 02:00 AM
Views 915
28-09-2022, 06:39 AM
Views 198
30-06-2021, 10:51 AM
Last Post by phaebo
Views 253
20-03-2021, 10:31 PM
Views 661
14-02-2021, 09:05 PM
Views 777
27-01-2021, 12:25 AM
Last Post by reganlives
Views 215
07-03-2020, 12:49 PM
Views 628
16-03-2019, 08:58 AM
