JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Vacuum bypass valve
Vacuum bypass valve
Vacuum bypass valve
phaebo
06-03-2022, 04:50 AM
#41
Thats how it needs to be But you are building it in opposite direction on your setup arent you lexusdaydreaming?
phaebo
06-03-2022, 04:50 AM #41
196
06-03-2022, 07:42 AM
#42
mine will be like the picture except the bypass pipe will be coming from before the throttle and then going to the bypass valve with the pipe part sticking out and flat part of valve being mounted to inlet t piece. this is correct?
lexusdaydreaming
06-03-2022, 07:42 AM #42
phaebo
06-03-2022, 07:51 AM
#43
Yes i think that will work
phaebo
06-03-2022, 07:51 AM #43
196
06-03-2022, 04:40 PM
#44
does the bypass valve need a small t piece and another hose to be taped into a vacuum line? or is it air flow operated? i cant find how to install it anywhere.
lexusdaydreaming
06-03-2022, 04:40 PM #44
06-03-2022, 05:46 PM
#45
Im sure u mount a join after the charger before the fmic and then one into the air filter side
06-03-2022, 05:46 PM #45
06-03-2022, 07:46 PM
#46
i dont mean air pipeing. but its said to be vacuum so do i need to tap into a vacuum pipe as there is a small pipe on the bypass valve.
lexusdaydreaming
06-03-2022, 07:46 PM #46
rob
07-03-2022, 05:02 AM
#47
Its vacuum pressure operated so it needs a vacuum pressure source to operate.
rob
07-03-2022, 05:02 AM #47
196
18-03-2022, 03:07 PM
#48
Does anyone have any pictures of where exactly I put the bypass vacuum pipe and bouts gauge vacuum pipe ? And bov? It's it all the same line
lexusdaydreaming
18-03-2022, 03:07 PM #48
18-03-2022, 04:21 PM
#49
At the side of the throttle there's 2 pipes coming off, it's the bottom one to need. VERY fiddly
18-03-2022, 04:21 PM #49
18-03-2022, 05:42 PM
#50
I would love a picture I found the two pipes and followed one off to the left.
lexusdaydreaming
18-03-2022, 05:42 PM #50
Views 869
26-08-2024, 09:45 AM
Last Post by phaebo
Views 780
05-04-2024, 07:48 AM
Views 2,386
28-09-2023, 12:28 PM
Views 522
30-06-2022, 04:40 PM
Last Post by phaebo
Views 707
21-03-2022, 04:20 AM
Views 1,909
15-02-2022, 02:54 AM
Views 1,787
27-01-2022, 06:14 AM
Last Post by reganlives
Views 498
07-03-2021, 06:38 PM
Views 1,459
15-03-2020, 02:46 PM
