Pages (135): Previous 149 50 51 52 53135 Next
25-01-2020, 12:29 PM
You can get distribution blocks for vac feeds, like this
[Image: vacuum-block.jpg]
25-01-2020, 12:29 PM #501
25-01-2020, 01:05 PM
Or likethe one I sold only a couple of weeks ago to stix.
25-01-2020, 01:05 PM #502
25-01-2020, 01:06 PM
You can use one line and t off it.
Though I'd keep the wastegate boost line separate.
25-01-2020, 01:06 PM #503
27-01-2020, 06:00 AM
looking good mate
27-01-2020, 06:00 AM #504
looking good mate
Jimbob-T-Lex
Moderator
1,674
28-01-2020, 08:20 AM
Well today i dremelled the rocker cover so the front injector plug fits so thats the injectors and fuel rail all fitted
Also had a little play with the intake manifold and throttle body this now all fits and the all the belts are now fitted so had a little bit of luck as i thought i wouldnt be able to adjust the alternator enough to tighten the belt
[Image: IMG_1416_zps76868d69.jpg]
Fitted the new ally radiator though cant find one of the bottom rubbers in the garage somewhere i guess lol
[Image: IMG_1412_zps01ca46d7.jpg]
[Image: IMG_1409_zpsbb6bc6d4.jpg]
[Image: IMG_1408_zpsa423bcb9.jpg]
Drilled the inlet manifold for the vacuum so now that is all done
[Image: IMG_1419_zps8bc987bd.jpg]
[Image: IMG_1417_zps9662b41f.jpg]
Put the oil pipes on the sandwich plate and routed them to the front now that was a tight squeeze to get them fitted lol also put the oil temp sensor on but im going to have to get a oil pressure senor relocation kit as there is not enough room down there!
[Image: IMG_1422_zps9406c6d3.jpg]
Getting on well but space is getting smaller in that bay lol
one question down on the right behind the radiator i dont think i can get a 2.5" pipe from the intercooler lol is there a specific way?? seems like the aircon pump needs to be sacrificed lol
Jimbob-T-Lex
28-01-2020, 08:20 AM #505
28-01-2020, 11:47 AM
I had aircon mate and it fitted so hopefully will fit mate
28-01-2020, 11:47 AM #506
Jimbob-T-Lex
Moderator
1,674
28-01-2020, 12:38 PM
i tried to fit 2.5" pipe down but no luck though there is a lil bracket with a plug on down there so ill chase up see what that is! Oh yeah do i need to cut any out of the crash bar for the intercooler mate?
Jimbob-T-Lex
28-01-2020, 12:38 PM #507
28-01-2020, 12:52 PM
jimbob150385 i tried to fit 2.5" pipe down but no luck though there is a lil bracket with a plug on down there so ill chase up see what that is! Oh yeah do i need to cut any out of the crash bar for the intercooler mate?
Erm all of it lol.
What diameter are the pipes I sent?
28-01-2020, 12:52 PM #508
Erm all of it lol.
Jimbob-T-Lex
Moderator
1,674
28-01-2020, 12:54 PM
Oh right don't fit it lol 2.5" pipe mate
Jimbob-T-Lex
28-01-2020, 12:54 PM #509
28-01-2020, 01:12 PM
jimbob150385 Oh right don't fit it lol 2.5" pipe mate
Hmm, I'm not sure why it doesn't fit then mate sorry, I didn't think it would be that different, though the pipes go right against the chassis leg I think.
Quick thought, you have cut out the protecting slots on the back of the fans?
28-01-2020, 01:12 PM #510
 4 Guest(s)
 4 Guest(s)
Views 5,124
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,865
25-03-2024, 02:10 AM
Views 9,084
23-03-2024, 03:45 PM
Views 20,375
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,485
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
Views 3,136
04-10-2023, 03:52 PM
Replies 76
Views 2,811
30-09-2023, 01:24 AM
Last Post by RichS11
