JapCarForum Cars, Cars, Cars! Project Cars My IS-V8-Turbo
My IS-V8-Turbo
My IS-V8-Turbo
Pages (53): Previous 149 50 51 52 53 Next
17-12-2016, 05:25 AM
I'd be very surprised if the outside temperature sensor ran off the ECU but then again with canbus and multiplexed wiring in modern cars anything is possible...
17-12-2016, 05:25 AM #511
2tongues Everything in mine works - apart from the outside temp display I just get "--"? don't know where the sensor is, or where the wiring goes to see if TGT "forgot" to plug something in, or if its the ECU missing something????????
The outside air temp sensor is behind the front bumper. Check out this diagram.
17-12-2016, 05:25 AM #512
17-12-2016, 05:33 AM
steviewevie The outside air temp sensor is behind the front bumper. Check out this diagram.
And according to this one it directly connects to the back of the clock unit:
http://www.bahamutcars.com/workshop/IS_9...code=clock
17-12-2016, 05:33 AM #513
17-12-2016, 05:35 AM
id say its worked the connection loose behind the bumper i have forgot to reconect it when the bumper was off once so id start there you might even beable to get at it if you take the grill out ...
17-12-2016, 05:35 AM #514
17-12-2016, 05:39 AM
toxo And according to this one it directly connects to the back of the clock unit:
Yeah but does it work without those other connections coming into the A/C and clock unit (e.g. the MPX stuff) being functional ? I don't know either way, it would be interesting to find out.
17-12-2016, 05:39 AM #515
17-12-2016, 05:44 AM
steviewevie Yeah but does it work without those other connections coming into the A/C and clock unit (e.g. the MPX stuff) being functional ? I don't know either way, it would be interesting to find out.
By virtue of the fact that it can fail singularly I would assume so. But you know what they say about assumptions. I'll check it out on Phil's car if he doesn't beat me to it Wink
BTW, are you *sure* that sensor you've indicated feeds the dash display? I ask because the books say it's the ambient temp sensor for the aircon, which most a/c systems have to stop their compressors engaging at near-to-freezing temperatures (even my car has one). It could easily be dual purpose but Toyota usually indicate that...
Edit: Actually scratch that, Rabster said he unplugged it and it stopped it working didn't he... :o
17-12-2016, 05:44 AM #516
17-12-2016, 05:50 AM
Will have a look, there is a good chance its not plugged in as TGT re-sculptured the bumper so it was stripped down, the sensor may not even be there....... Not the end of the world though.
17-12-2016, 05:50 AM #517
Looking again at that diagram, all that shows is the external temp gauge inside the clock unit, not the temp sensor plugging directly into it. The ambient air sensor plugs into the engine ECU, as per this diagram. That's the only external air temp sensor that I'm aware of, so I'm assuming it serves two purposes, but I might have missed something !
17-12-2016, 05:50 AM #518
17-12-2016, 05:56 AM
well mine was off and temp dint work but dont hold me to this as i ahd lots of bits of the car at the time lol
including most the dash
17-12-2016, 05:56 AM #519
17-12-2016, 09:32 AM
right been down to my cousin garage and seen my mate bmw who was doing a v8 conversion finished today sounds like mines lol
well phoned up thor racing today and they said they have the bell housing in stock just waiting for the trans bracket to be made so i am going to order that tomorrow so they going to send that out and once the bracket is made end of feb and that will be sent out.
so far speaking to my cousin mechanic and he goes if your going to change the coilovers and change it to manual then might aswell drop the front out because the manifold gaskets are needing changed and they aint room to take them out and once the engine out check everything over and make sure everything is fine and put it back in so you know for 100% the engine done right.
so he has got me thinking. the money aint a problem because i get charged what my cousin pays the mechanic so aint bad.
will update tommarow with the decision i make
17-12-2016, 09:32 AM #520
Views 77,552
08-02-2024, 01:53 AM
Replies 23
Views 1,692
04-01-2023, 03:30 PM
Last Post by aaron1991ellis
Replies 65
Views 5,490
21-12-2022, 09:37 AM
Last Post by jeffrosie
Replies 179
Views 15,545
17-12-2022, 10:34 AM
Last Post by phaebo
Replies 39
Views 4,406
13-12-2022, 01:00 PM
Last Post by N15_GTi
Replies 69
Views 13,573
25-11-2022, 04:48 AM
Views 3,738
30-07-2022, 06:45 PM
Last Post by Lexus RS200T
Replies 1,318
Views 95,987
05-06-2022, 08:23 AM
Last Post by sarah0
Views 3,887
11-11-2021, 01:10 AM
Views 2,240
20-06-2021, 04:50 AM
