Pages (135): Previous 151 52 53 54 55135 Next
01-02-2020, 04:21 AM
Condensor then!
01-02-2020, 04:21 AM #521
Condensor then!
Jimbob-T-Lex
Moderator
1,674
01-02-2020, 09:52 AM
condenser in car terms pmsl
Jimbob-T-Lex
01-02-2020, 09:52 AM #522
Jimbob-T-Lex
Moderator
1,674
02-02-2020, 04:48 AM
Is the is200 individual injection?? Do you splice in the cable with the injector or snip and have go through the greddy?? The add/trim way
Jimbob-T-Lex
02-02-2020, 04:48 AM #523
02-02-2020, 05:10 AM
Yes it's direct, you can just tap in but I'd cut and connect both sides personally so you can add and remove.
02-02-2020, 05:10 AM #524
Jimbob-T-Lex
Moderator
1,674
02-02-2020, 05:13 AM
Yeah that's what I done so can add and trim cheers for confirmation mate
Jimbob-T-Lex
02-02-2020, 05:13 AM #525
02-02-2020, 05:28 AM
Make sure you get it the right way round. When putting the engine and ecu side on
02-02-2020, 05:28 AM #526
Jimbob-T-Lex
Moderator
1,674
03-02-2020, 12:58 AM
yeah got that all ok mate just got few wires left!! like analogue input and output which i think is for the tuning within a rev range, vehicle speed signal input and output i cant find on ecu, injector input 7 and 8 which are not used, throttle position sensor input which i assume gets taken off the new throttle TPS?? and then my air flow frequency input and airflow voltage input and output which i guess comes off the new MAP sensor??
Jimbob-T-Lex
03-02-2020, 12:58 AM #527
03-02-2020, 01:10 AM
Yep off the map.
The speed signal goes from the gearbox to the dash then to the ecu. So you want the speed wire from dash to ecu.
03-02-2020, 01:10 AM #528
Yep off the map.
Jimbob-T-Lex
Moderator
1,674
03-02-2020, 01:15 AM
Just wondering what if your using the greddy 3 map sensor as this just plugs straight in to the greddy ultimate?
Jimbob-T-Lex
03-02-2020, 01:15 AM #529
03-02-2020, 01:24 AM
But the emanage needs to send the fake signal to the ecu to stop it hitting boost cut. The 3bar sensor is used for mapping as its more accurate than the standard one. But the standard one needs to stay for the standard ecu.
03-02-2020, 01:24 AM #530
 5 Guest(s)
 5 Guest(s)
Views 5,124
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,865
25-03-2024, 02:10 AM
Views 9,085
23-03-2024, 03:45 PM
Views 20,385
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,485
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
Views 3,136
04-10-2023, 03:52 PM
Replies 76
Views 2,811
30-09-2023, 01:24 AM
Last Post by RichS11
