Pages (135): Previous 153 54 55 56 57135 Next
Jimbob-T-Lex
Moderator
1,674
04-02-2020, 06:10 AM
Getting handy on paint lol think this is what i have to do but the 4th wire is doing me??
[Image: b9c48764-b779-4808-b343-0e6fbc9fea63_zpsf6a1c0fc.jpg]
Jimbob-T-Lex
04-02-2020, 06:10 AM #541
04-02-2020, 06:15 AM
Your right the 4th wire is a switch for idle. The ecu will need it, hmm not sure how to tackle that one ill have to think.
2 map sensors? Where? I thought there was just one on the manifold, the other pipe goes to a vsv valve as part of the carbon canister setup.
04-02-2020, 06:15 AM #542
Jimbob-T-Lex
Moderator
1,674
04-02-2020, 06:18 AM
aahhh its ok its because i had to engines one still connected to car lol yeah thought it was to do with idle **** it lol unless i just change the tps for a 4 wired one which will eliminate that problem
Jimbob-T-Lex
04-02-2020, 06:18 AM #543
04-02-2020, 06:23 AM
Yeah could you not fit the standard tps to the throttle? I'm sure I've a couple spare if you want to experiment?
I'd be interested in the aftermarket tps you have if your successful.
04-02-2020, 06:23 AM #544
Jimbob-T-Lex
Moderator
1,674
04-02-2020, 06:31 AM
i aint got the space to fit it in mate its tight near the alternator already
Jimbob-T-Lex
04-02-2020, 06:31 AM #545
Jimbob-T-Lex
Moderator
1,674
04-02-2020, 09:53 AM
what is the problem if i dont connect my idle wire then in theory i will control the idle by the screw on the throttle body?? or is the ecu just going to do into failsafe mode?? i just cant get my head round this how has everyone else done this aaarrrrgggg!!!!!!!! lol
Jimbob-T-Lex
04-02-2020, 09:53 AM #546
04-02-2020, 10:30 AM
I don't know that's the problem, if it just messes with the idel, like you say that's fine. But if it fail safes it not sure what to do.
The only others i know are Dave and lexiis and I think their both on standalone
04-02-2020, 10:30 AM #547
04-02-2020, 10:34 AM
It won't like not having the IDL signal. I disconnected mine on the MR2 when I was mucking about with the GT4 ECU and it stalled at idle when warm. IDL is just a microswitch inside the TPS which switches on when the throttle plate is closed, so the ECU knows to open the idle control valve and that the engine has no load on it.
04-02-2020, 10:34 AM #548
Jimbob-T-Lex
Moderator
1,674
04-02-2020, 10:46 AM
well after a lil research i need a 4.7kohm resistor on the the motor circuit which will make the ecu think that the motor is still connected so then that can come out i can then piggy back all the position sensors onto the new one on the throttle body in theory i can see this working but like you say as long as the idle signal missing does not chuck it into limp mode i should be ok
Jimbob-T-Lex
04-02-2020, 10:46 AM #549
04-02-2020, 02:07 PM
Just a thought, you could wire a microswitch to the throttle pedal or throttle body so when your at idle (off the pedal) it sends the right signal. Simples lol
04-02-2020, 02:07 PM #550
 4 Guest(s)
 4 Guest(s)
Views 5,124
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,865
25-03-2024, 02:10 AM
Views 9,085
23-03-2024, 03:45 PM
Views 20,385
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,485
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
Views 3,136
04-10-2023, 03:52 PM
Replies 76
Views 2,811
30-09-2023, 01:24 AM
Last Post by RichS11
