Pages (135): Previous 155 56 57 58 59135 Next
john wan
10-02-2020, 05:50 AM
Know what you mean about the weather top half of me is alright just me ****** legs an feet get wet an cold ha ha ha
john wan
10-02-2020, 05:50 AM #561
Jimbob-T-Lex
Moderator
1,674
11-02-2020, 08:07 AM
Well got a lil bit done this weekend but freezing out there
Well the manifold and wastegate are now all fitted so the turbo could go on and i could start the plumbing of intercooler
[Image: 56AB42F5-921B-435D-8A12-CA56E86E4B4A-876...cfeec9.jpg]
[Image: 45AF95D7-1A2E-4032-BAFA-4C0CA6F9FCEF-876...e681e3.jpg]
Still got to do the turbo side of the intercooler and remount the left and right impact sensors
Got the 3 lambda sensor bosses welded on the down pipe so fitted them also today
[Image: 02381916-1906-4748-A5AE-35246EF5E629-876...6ba70b.jpg]
Fitted the plugs onto the gearbox as forgot bout them oops lol
2 x questions what is this pipe for that runs underneath from the engine bay a vacuum for something i think and has what i think is a filter???
[Image: AADF520F-6467-4817-BC54-C4E63D5875E5-876...ca74ec.jpg]
Also on the map sensor is there any need to keep the screw end on or can i just take off and plumb straight into vacuum manifold?? the screw end looks too big to be just a vacuum tap off??
[Image: 791D97C0-72E6-436B-BD4A-49F9E67D07A6-876...10358f.jpg]
Slowly getting there still few bits to do with wiring like the injectors, changing the drive by wire and few greddy wires left
plumb the turboside intercooler
fit oilcooler on the front
fit oil pressure switcg relocator
greddy 3 bar map sensor
fit and plumb vacuum manifold
wire in FCD
fit micro switch to pedal for idle signal
As you can see still a fair bit but got week after next off so ill get alot done then but starting to look the part just need to get is sounding the part pmsl
Jimbob-T-Lex
11-02-2020, 08:07 AM #562
wire in FCD
mattlaw
11-02-2020, 08:14 AM
Maybe a daft question but why3 lambda sensors? Wouldn't it have been easier to splice the front 2 together and then use a sim for the rear?
mattlaw
11-02-2020, 08:14 AM #563
Jimbob-T-Lex
Moderator
1,674
11-02-2020, 08:18 AM
No particular reason mate there was enough room so went with three 2 are from the normal manifold and 1 is for my air/fuel gauge and then still got my one at the rear
Jimbob-T-Lex
11-02-2020, 08:18 AM #564
The 'screw-on' bit on the MAP sensor is a filter. You should keep it.
Edited 24-03-2013, 05:54 PM by toxo.
11-02-2020, 08:18 AM #565
Jimbob-T-Lex
Moderator
1,674
11-02-2020, 08:20 AM
Sweet cheers toxo appreciated one question down Smile
Jimbob-T-Lex
11-02-2020, 08:20 AM #566
Jimbob-T-Lex
Moderator
1,674
11-02-2020, 10:37 AM
Oh forgot to ask anyone got a bottom rubber mount for the radiator mine has been nicked by the fairys!! pmsl
Jimbob-T-Lex
11-02-2020, 10:37 AM #567
11-02-2020, 01:48 PM
jimbob150385 Oh forgot to ask anyone got a bottom rubber mount for the radiator mine has been nicked by the fairys!! pmsl
Ask the sxe boys. Should be one on the sick bucket.
11-02-2020, 01:48 PM #568
11-02-2020, 01:49 PM
And the pipe is for the carbon canister Eco thing. Unneeded but the ecu will have a fit so leave it for now.
11-02-2020, 01:49 PM #569
Jimbob-T-Lex
Moderator
1,674
11-02-2020, 01:54 PM
Oh right so just plumb this into my vacuum manifold aswell then cheers mate ur engine is looking good mate!!!! Just want to get mine started then do all the tidy up of bay and wiring after
Jimbob-T-Lex
11-02-2020, 01:54 PM #570
 11 Guest(s)
 11 Guest(s)
Views 5,124
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,865
25-03-2024, 02:10 AM
Views 9,086
23-03-2024, 03:45 PM
Views 20,385
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,485
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
Views 3,136
04-10-2023, 03:52 PM
Replies 76
Views 2,811
30-09-2023, 01:24 AM
Last Post by RichS11
