JapCarForum Cars, Cars, Cars! Project Cars Lexus is200 se
Lexus is200 se
Lexus is200 se
Pages (42): Previous 14 5 6 7 842 Next
is200turbo
01-10-2022, 08:14 AM
#51
They are mate and are finished real good, I don't think they will take much fitting before painting
is200turbo
01-10-2022, 08:14 AM #51
is200turbo
02-10-2022, 05:37 AM
#52
Is this engine a straight swap?
371306075817 eBay number
is200turbo
02-10-2022, 05:37 AM #52
02-10-2022, 07:55 AM
#53
No, it's not too hard you need custom engine mounts then the wiring sorted.
02-10-2022, 07:55 AM #53
is200turbo
02-10-2022, 08:26 AM
#54
Not that bad then really, I will keep looking as I want to do the body and suspension first
is200turbo
02-10-2022, 08:26 AM #54
02-10-2022, 08:58 AM
#55
You'd be better off swapping in the internals of the GTE into your existing FE and then doing a custom turbo manifold. That way you keep the VVT-i, you can build the engine, leave the car running on standard ecu until you can afford to go stand alone and then turbo it. And you don't have to faff about with engine mount/mods etc.
1g-gte rods and pistons for sale in this thread on driftworks:
http://www.driftworks.com/forum/parts-sa...parts.html
02-10-2022, 08:58 AM #55
is200turbo
02-10-2022, 09:00 AM
#56
If I go that route would I need the crank?
is200turbo
02-10-2022, 09:00 AM #56
02-10-2022, 09:03 AM
#57
From memory, no, they are the same. Stav will probably know for sure though. SamB went this route before putting a 1jz in his car.
02-10-2022, 09:03 AM #57
is200turbo
02-10-2022, 09:20 AM
#58
Are the shells and rings easy to get as I wouldn't want to put them in with out putting new in
is200turbo
02-10-2022, 09:20 AM #58
02-10-2022, 10:44 AM
#59
Depends on what generation the rods are of they are gen 1 then you'll need the crank if gen 2/3 then it's the same as the fe crank.
Rings aren't easy you have to adjust some others, shells are the same if fe crank
02-10-2022, 10:44 AM #59
is200turbo
02-10-2022, 11:14 AM
#60
I've just messaged the bloke on drift works to see if there still available, I will ask him what gen there from
is200turbo
02-10-2022, 11:14 AM #60
 3 Guest(s)
 3 Guest(s)
Views 5,037
09-04-2024, 01:09 AM
Views 1,259
06-04-2024, 05:57 PM
Views 102,654
25-03-2024, 02:10 AM
Views 9,052
23-03-2024, 03:45 PM
Views 67,512
08-02-2024, 01:53 AM
Views 398
18-12-2023, 02:55 AM
Views 1,467
08-10-2023, 03:59 AM
Views 5,943
06-10-2023, 02:58 AM
Views 3,101
04-10-2023, 03:52 PM
Replies 76
Views 2,747
30-09-2023, 01:24 AM
Last Post by RichS11
