Lexus 3S200 GTE Build
sorry to hear about another set back Phil
toxo Sounds like they've put in the motor from the MR2 which is a really odd idea considering there's an off-the-shelf pump that fits perfectly. Also the MR2 motor only really works properly with the MR2 ECU cause it needs speedo pulses, steering wheel position pulses, and all sorts to the P/S ECU (which is seperate)... might be why yours is making complaining noises if it has (for example) been wired up to run all the time.
The power steering pump location on the GT4 IIRC is where the alternator is mounted on the MR2 (and therefore the brackets & belts are different) so you might need to relocate that if you go for a GT4 PS setup. Unfortunately in your case, the alternator location on the GT4 is more or less where your turbo is... sounds like SPC are in for fun times ahead!
2tongues All the complex bits have been removed and the pump is on all the time. I wonder if the aircon pump can be removed as I rarely use that and a PS pump put there instead?
2tongues All the complex bits have been removed and the pump is on all the time.!!!!
2tongues I wonder if the aircon pump can be removed as I rarely use that and a PS pump put there instead?
sorry to pee on you fireworks totounges but il be knocking you down a peg in a cupple of days.
tehe:thumbup:
jamie. 330bhp and climbing
steviewevie hock:
Don't get rid of your aircon !
steviewevie hock:
SPChorsham.com sorry to pee on you fireworks totounges but il be knocking you down a peg in a cupple of days.
tehe:thumbup:
tehe:thumbup:
2tongues TGT broke the filler pipe and at nearly £800 to replace (fitted, gassed etc by Lexus) I can't see that happening any-time soon.
My car is 2005. I let Lexus quote and the whole pipe is 200+ vat, + 5 hours fitting = £650+vat = £747.50 this year and £763.75 next year due to the VAT increase. Ouch. Then again TGT broke it so I think I will add this to the list........................
I could see if it is easy to DIY?????
