Pages (135): Previous 164 65 66 67 68135 Next
27-02-2020, 11:51 AM
are you def physically moving the throttle the full 90 degrees?
27-02-2020, 11:51 AM #651
Jimbob-T-Lex
Moderator
1,674
27-02-2020, 11:53 AM
yeah its definately moving the full 90 degrees just went and checked mate
Jimbob-T-Lex
27-02-2020, 11:53 AM #652
27-02-2020, 12:05 PM
does seem a low range then for that sort of movement,hmm not sure mate
27-02-2020, 12:05 PM #653
Jimbob-T-Lex
Moderator
1,674
28-02-2020, 09:48 AM
well i got her started but sounds like the timing is out, still not worked this position sensor problem.
What i did was set the position sensor to the correct voltage for the idle and put the motor back in line so that all as is it was normal.
I can start the car but it just dies out and some times get a pop
I set the I/J settings in the greddy to 155cc normal and 550cc now though there is a lag setting i just left alone
Ignitors are as standard settings for is200
Is there any other settings i need to do???
Jimbob-T-Lex
28-02-2020, 09:48 AM #654
john wan
28-02-2020, 10:21 AM
Ahhhh yuh beat me to it ha ha shweeeet
john wan
28-02-2020, 10:21 AM #655
Jimbob-T-Lex
Moderator
1,674
28-02-2020, 10:25 AM
Well it starts not ticking over right though lol yours will be drivable before mine!!!
Jimbob-T-Lex
28-02-2020, 10:25 AM #656
john wan
28-02-2020, 10:48 AM
Ha ha ha if I ever get the time off to fit it all
john wan
28-02-2020, 10:48 AM #657
Jimbob-T-Lex
Moderator
1,674
28-02-2020, 10:51 AM
I still got to get them position sensors sorted out though
Jimbob-T-Lex
28-02-2020, 10:51 AM #658
Jimbob-T-Lex
Moderator
1,674
28-02-2020, 11:56 AM
[Image: th_Carrunning_zpsd2ddd207.jpg]
There you go proof it does sort of tick over lol
Jimbob-T-Lex
28-02-2020, 11:56 AM #659
Jimbob-T-Lex
Moderator
1,674
28-02-2020, 12:14 PM
just thought i have not set the boost cut limiter like sparky said so that will sort the problem i got with when i accelerate it bogs out to nearly stall amateur mistake lol
Jimbob-T-Lex
28-02-2020, 12:14 PM #660
Views 5,125
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 102,868
25-03-2024, 02:10 AM
Views 9,088
23-03-2024, 03:45 PM
Views 20,386
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,486
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
Views 3,137
04-10-2023, 03:52 PM
Replies 76
Views 2,811
30-09-2023, 01:24 AM
Last Post by RichS11
