Pages (132): Previous 1 … 68 69 70 71 72 … 132 Next
16-02-2018, 10:05 AM
How big is the stock MAP sensor, you're not maxing that out are you? It would need to be at least a 2.5BAR MAP sensor to cope with what you're doing to it. (1 BAR is sea level, then for arguments sake 1.2 BAR boost, plus room for manoever, atmospheric changes etc). They do VERY weird things when they go over their limit, I know the stock Toyota sensor on my car doesn't work reliably at its top end.
If that were the case, surely they can just use any old GM MAP sensor? Standalone EMS is usually configurable enough to use a generic pressure sensor, and seeing as GReddy went bust last year I'd have thought getting a specific sensor could be problematic?
You will get to a point where the injectors are large enough that the fuel lines, FPR, fuel rail and fuel pump become restrictive. Doesn't happen on the '2 as the injectors are 540cc as standard so the stock kit works for big power but I know yours are smaller.
Edited 30-03-2010, 01:52 PM by toxo.
16-02-2018, 10:05 AM #691
53
16-02-2018, 10:40 AM
toxo How big is the stock MAP sensor, you're not maxing that out are you? It would need to be at least a 2.5BAR MAP sensor to cope with what you're doing to it. (1 BAR is sea level, then for arguments sake 1.2 BAR boost, plus room for manoever, atmospheric changes etc). They do VERY weird things when they go over their limit, I know the stock Toyota sensor on my car doesn't work reliably at its top end.
we use the AEM FIC,that has a internal map sensor.
SPChorsham.com
16-02-2018, 10:40 AM #692
16-02-2018, 11:02 AM
I don't know the top-end bhp figure. I'm not so interested in that, since I'm after driveability, but I am trying to find out if they've got a figure for it.
As for the OEM MAP sensor, Noble say it can easily cope with my turbo and has plenty of headroom.
16-02-2018, 11:02 AM #693
53
16-02-2018, 12:38 PM
steviewevie I don't know the top-end bhp figure. I'm not so interested in that, since I'm after driveability, but I am trying to find out if they've got a figure for it.
you can only run up to 0.3bar with the std map sensor.
SPChorsham.com
16-02-2018, 12:38 PM #694
16-02-2018, 01:44 PM
SPChorsham.com you can only run up to 0.3bar with the std map sensor.
Noble have been running my car with the OEM MAP sensor and more boost than that, so I'm not sure that you can be correct :confused1:
16-02-2018, 01:44 PM #695
16-02-2018, 01:49 PM
toxo seeing as GReddy went bust last year I'd have thought getting a specific sensor could be problematic?
I think that the rumours of GReddy's demise were exaggerated/misunderstood. For example, see this press release, they're still going.
16-02-2018, 01:49 PM #696
16-02-2018, 02:06 PM
Dave Ellen's original IS200 turbo used the stock MAP sensor as far as I can tell, and ran over 0.3 bar of boost. Pretty sure some other turbos have too. Also pretty sure that some people have pushed their superchargers over 0.3 bar on the stock MAP sensor.
16-02-2018, 02:06 PM #697
16-02-2018, 02:10 PM
Sams is on standard MAP I think.
16-02-2018, 02:10 PM #698
16-02-2018, 02:42 PM
Gord They had the same problem when they mapped the MR2 turbo, Dave Ellen told them that it defo 100% needed bigger injectors, in the end stock injectors worked 100% better, and to this day the MR2 still running stock injectors :thumbup:
Possibly slightly different as MR2 turbo (especially 1994+) injectors are HUGE as standard, nearly 200cc more than an S14 of the same age for example. The engine management in the '2 runs incredibly rich as a result (10:1 AFR *stock* on boost) as a retarded way of trying to protect the engine.
16-02-2018, 02:42 PM #699
16-02-2018, 02:54 PM
Gord Yes that true Stevie, off the top of my head i know of 4 turbo is200 and a few supercharged one still running stock MAP sensor, for a few years now tooo Big Grin
ok this might sound daft but what is a map sensor ??
16-02-2018, 02:54 PM #700
Views 15,289
Views 4,172
Views 5,127
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 181,032
Views 23,704
Views 49,451
Views 147,509
Views 1,387
Views 4,014
Views 6,964
