Pages (135): Previous 170 71 72 73 74135 Next
21-03-2020, 12:41 PM
That hopefully can be mapped out mate don't worry. Glad it's running
21-03-2020, 12:41 PM #711
Jimbob-T-Lex
Moderator
1,674
23-03-2020, 11:02 AM
well today i found some vacuum leaks and sorted idle is alot better now
i took her for a little drive and when i come up to positive boost it sounds as if the waste gate goes and then when i come to a stand still the car stalls is the stall down to the fuel cut settings?
i dont actually get into positive boost! my vacuum is 15 psi which is not brilliant should be a little higher than that
I looked into my boost controller and i have got it set up to 0.5 bar but i barel get to 0 bar
Jimbob-T-Lex
23-03-2020, 11:02 AM #712
23-03-2020, 11:53 AM
Is the wastegate plumbed the right way?
As for the stalling. That will be related to the throttle setup IMHO. You need to add a standalone icv run by the emanage.
23-03-2020, 11:53 AM #713
Jimbob-T-Lex
Moderator
1,674
23-03-2020, 11:55 AM
I literally just said to my dad that I could be something like that lol
Jimbob-T-Lex
23-03-2020, 11:55 AM #714
Jimbob-T-Lex
Moderator
1,674
ICV ??? Lol I'm tired
Jimbob-T-Lex
23-03-2020, 11:55 AM #715
Jimbob-T-Lex
Moderator
1,674
23-03-2020, 11:58 AM
Idle control valve lol
Jimbob-T-Lex
23-03-2020, 11:58 AM #716
23-03-2020, 01:42 PM
Yep. I've used one off a vauxhall.
23-03-2020, 01:42 PM #717
Jimbob-T-Lex
Moderator
1,674
24-03-2020, 01:06 AM
Where you mount that mate got any pics
Jimbob-T-Lex
24-03-2020, 01:06 AM #718
24-03-2020, 02:35 AM
I made a little bracket and adapter from the inlet manifold. Ill get some pics of it fitted.
One of the icv:
[Image: yhyde5y6.jpg]
You can see the adapter on the side ofthe manifold here:
[Image: ehemy3ad.jpg]
I just tapped the hole and screwed the adapter in
It can be controlled by pulse width modulation from the ecu.
24-03-2020, 02:35 AM #719
One of the icv:
Jimbob-T-Lex
Moderator
1,674
24-03-2020, 04:57 AM
well this is getting a little more complicated lol
Today i took her out and the fluttering noise i am getting is not my BOV or the wastegate where the hell is it coming from???
When i hit boost the car is bogging and then the revs die down to eventually stalling like a fail safe im a little lost now!!
Jimbob-T-Lex
24-03-2020, 04:57 AM #720
 3 Guest(s)
 3 Guest(s)
Views 5,128
09-04-2024, 01:09 AM
Views 1,290
06-04-2024, 05:57 PM
Views 102,879
25-03-2024, 02:10 AM
Views 9,089
23-03-2024, 03:45 PM
Views 20,387
18-02-2024, 11:42 PM
Views 404
18-12-2023, 02:55 AM
Views 1,488
08-10-2023, 03:59 AM
Views 6,010
06-10-2023, 02:58 AM
Views 3,137
04-10-2023, 03:52 PM
Replies 76
Views 2,812
30-09-2023, 01:24 AM
Last Post by RichS11
