JapCarForum Cars, Cars, Cars! Project Cars Supercharged Lexus IS200 SE
Pages (132): Previous 177 78 79 80 81132 Next
12-07-2021, 01:53 PM
Its mounted on a silicone T pipe similar to what u would use for a BOV, but has a custom mount plate that reduces the diameter down to 25mm. Thats it really mate.
12-07-2021, 01:53 PM #781
Xtremist
12-07-2021, 01:57 PM
And where does your vacuum hose come from
Xtremist
12-07-2021, 01:57 PM #782
12-07-2021, 02:03 PM
From the only vacuum point on the car under the throttle body,
Theres a line that comes out from the side, u need to T into that and run it to the bypass
12-07-2021, 02:03 PM #783
posty
And you need tiny hands to get to it!
posty
12-07-2021, 02:03 PM #784
12-07-2021, 02:05 PM
[Image: 20140712_135949_zps1wopuriu.jpg]
This is the only pic I have on my phone of the bypass
12-07-2021, 02:05 PM #785
ZAIS200
12-07-2021, 02:42 PM
I've been wanting to see how the bypass fits my next question would be about this clutch that everybody talks about, i'm intrigued to see how this clutch is wired up i'm assuming one wire goes to ignition (as in your case pat) and one to ground as chassis or body, am i correct?
P.s: where or how did you get the 2" pipe fitting for the bypass, the bypasses i've seen on fleabay don't come with them.
Edited 24-08-2014, 12:24 AM by ZAIS200.
ZAIS200
12-07-2021, 02:42 PM #786
12-07-2021, 11:36 PM
The pipe for the bypass was made by Fossil Fuels,
All it is is a flat plate with a hole in the middle and then a small length of metal pipe off the one side to attach it.
With regards the clutch Neg runs to the Neg of battery and the Pos rusns to an ignition source in the car, I used the cig lighter
12-07-2021, 11:36 PM #787
12-07-2021, 11:41 PM
[Image: received_m_mid_1396456469237_6201bd34981...baajq.jpeg]
Heres a pic of the mount for the bypass
12-07-2021, 11:41 PM #788
Xtremist
13-07-2021, 02:20 AM
Ah Ok that looks pretty simple to make
Xtremist
13-07-2021, 02:20 AM #789
Shack
13-07-2021, 02:46 AM
Hey Pat, thanks for the help before. This is an awesome build! loving all the information here mate! Keep us posted with heaps more mods =D
Shack
13-07-2021, 02:46 AM #790
 7 Guest(s)
 7 Guest(s)
Views 5,441
09-04-2024, 01:09 AM
Views 1,410
06-04-2024, 05:57 PM
Views 9,667
23-03-2024, 03:45 PM
Views 21,316
18-02-2024, 11:42 PM
Views 71,360
08-02-2024, 01:53 AM
Views 452
18-12-2023, 02:55 AM
Views 1,571
08-10-2023, 03:59 AM
Views 6,308
06-10-2023, 02:58 AM
Views 3,306
04-10-2023, 03:52 PM
Replies 76
Views 3,104
30-09-2023, 01:24 AM
Last Post by RichS11
