Pages (135): Previous 177 78 79 80 81135 Next
Jimbob-T-Lex
Moderator
1,674
31-03-2020, 03:11 AM
Not had a pm yet mate??
Jimbob-T-Lex
31-03-2020, 03:11 AM #781
31-03-2020, 09:51 AM
cant wait to see this at Jap power gonna be awesome Smile
31-03-2020, 09:51 AM #782
Jimbob-T-Lex
Moderator
1,674
31-03-2020, 10:11 AM
aslong as i aint next to sparkystav's mine wont look too bad lol
Jimbob-T-Lex
31-03-2020, 10:11 AM #783
31-03-2020, 10:36 AM
ill park you both at either end oog have we got an SC car going we could do an evolution of developments lol
31-03-2020, 10:36 AM #784
Jimbob-T-Lex
Moderator
1,674
31-03-2020, 10:39 AM
Lol we must have a sc coming
Jimbob-T-Lex
31-03-2020, 10:39 AM #785
31-03-2020, 11:57 AM
Don't worry mate mine won't be perfect either. As long as its there!
31-03-2020, 11:57 AM #786
Jimbob-T-Lex
Moderator
1,674
01-04-2020, 01:29 PM
Right got waste gate opening all properly now opens at 0.4 as that's the lowest the spring can do
I'm still getting the loss of power after a WOT boost waste gate opens I change gear and nothing all power is gone and then stalls
If it is that I'm limiting my injectors what can I do??
I looked at the injector adjust map and as I ain't got a 3 bar map sensor I have to adjust with throttle % I've up the number in the higher rev ranges but does not seen to make a difference??
Also I noticed that my fuel trims are high on the obd reader is this the standard ecu fighting the greddy?? I'm getting lost in this now help please lol
Jimbob-T-Lex
01-04-2020, 01:29 PM #787
01-04-2020, 01:40 PM
You really need to map against a map sensor. Though with the standard injectors on you don't really have to touch the map as the standard ecu will do it at that pressure.
Have you got the voltage clamp on to act as a black box for the standard fuel cut?
01-04-2020, 01:40 PM #788
ZAIS200
01-04-2020, 01:42 PM
Geez Jimbob, i hope you come right, i wish i could help but this ECU programming is all Greek to me good luck with it though i'll be following closely to see what the solution is
Edited 14-05-2013, 10:46 AM by ZAIS200.
ZAIS200
01-04-2020, 01:42 PM #789
Jimbob-T-Lex
Moderator
1,674
01-04-2020, 11:22 PM
Yeah got fuel cut a 4.26v
I've tried the injectors with all 0's and then I thought if I'm running out of fuel I'd adjust the figure in the higher throttle % but no change I'm thinking its a fuel matter as was fine when I had the 550 cc's on
Jimbob-T-Lex
01-04-2020, 11:22 PM #790
 11 Guest(s)
 11 Guest(s)
Views 5,130
09-04-2024, 01:09 AM
Views 1,291
06-04-2024, 05:57 PM
Views 102,880
25-03-2024, 02:10 AM
Views 9,095
23-03-2024, 03:45 PM
Views 20,394
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,490
08-10-2023, 03:59 AM
Views 6,019
06-10-2023, 02:58 AM
Views 3,139
04-10-2023, 03:52 PM
Replies 76
Views 2,817
30-09-2023, 01:24 AM
Last Post by RichS11
