Pages (135): Previous 178 79 80 81 82135 Next
john wan
01-04-2020, 11:59 PM
Why did u change them? Can you not set everything low cause there is loads of sc is200 s that are running on standard injectors then build up from there? If its still happening then surely its somthing else?
john wan
01-04-2020, 11:59 PM #791
02-04-2020, 12:50 AM
I'd remove the injector maps completely mate the only map you need active is the fuel cut at 4.34v IMHO.
02-04-2020, 12:50 AM #792
Jimbob-T-Lex
Moderator
1,674
02-04-2020, 01:07 AM
Ok mate will do could it be that still at 0.4 too much air for the injectors
Jimbob-T-Lex
02-04-2020, 01:07 AM #793
Jimbob-T-Lex
Moderator
1,674
02-04-2020, 12:40 PM
right idea im thinking i may have a open circuit in the WOT with the tps or aps as this only happens a WOT could be that when i shorts the 2 pins its not getting the WOT signal and cutting everything
Ill check tomorrow ****** hard this as its chucking no codes at me aaarrrgggghhhh lol
Jimbob-T-Lex
02-04-2020, 12:40 PM #794
02-04-2020, 12:50 PM
May sound silly but have you recalibrated rated the throttle voltages?
02-04-2020, 12:50 PM #795
Jimbob-T-Lex
Moderator
1,674
02-04-2020, 12:54 PM
What on the old throttle body?? Or in the greddy??
I checked the voltage before on the tps and aps before but only the 0.8v at idle so they were in tolerance but didn't check at wot so this could be it!
Jimbob-T-Lex
02-04-2020, 12:54 PM #796
02-04-2020, 12:56 PM
On the greddy, you can cal the throttle voltages cant you
02-04-2020, 12:56 PM #797
Jimbob-T-Lex
Moderator
1,674
02-04-2020, 01:03 PM
Yeah mate but the standard ecu not gonna like it lol
Jimbob-T-Lex
02-04-2020, 01:03 PM #798
02-04-2020, 01:07 PM
What do you mean? It's just a measurement the greddy takes, a reference. You just go to the thottle tab on the setup with the engine off and then it measures the voltage at closed and fully open.
02-04-2020, 01:07 PM #799
Jimbob-T-Lex
Moderator
1,674
02-04-2020, 01:16 PM
Yeah I can get measurements from there but you can also set up manually in the greddy oh I see what you saying mate it just sets parameters for the greddy it's been a long day lol
I beginning to think its todo with throttle body oem one as after it does stall I have to take key out of ignition lock and unlock and it will restart otherwise it won't restart
Jimbob-T-Lex
02-04-2020, 01:16 PM #800
 11 Guest(s)
 11 Guest(s)
Views 5,130
09-04-2024, 01:09 AM
Views 1,291
06-04-2024, 05:57 PM
Views 102,880
25-03-2024, 02:10 AM
Views 9,095
23-03-2024, 03:45 PM
Views 20,394
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,490
08-10-2023, 03:59 AM
Views 6,019
06-10-2023, 02:58 AM
Views 3,139
04-10-2023, 03:52 PM
Replies 76
Views 2,817
30-09-2023, 01:24 AM
Last Post by RichS11
