Pages (135): Previous 180 81 82 83 84135 Next
Jimbob-T-Lex
Moderator
1,674
06-04-2020, 05:47 AM
I don't get the ratio lol not really done this before
Jimbob-T-Lex
06-04-2020, 05:47 AM #811
Jimbob-T-Lex
Moderator
1,674
06-04-2020, 07:23 AM
so basically all my pistons rings are shall we say ******!!! then as im getting the impression that 150 is a minimum and should be at 180 PSI??
Jimbob-T-Lex
06-04-2020, 07:23 AM #812
06-04-2020, 09:54 AM
Doesnt have to be 180 mate as long as they're similar.
Not sure how rings would go so quickly?!
06-04-2020, 09:54 AM #813
Jimbob-T-Lex
Moderator
1,674
06-04-2020, 09:57 AM
Thats what i thought mate but im still getting smoke from my breather and dip stick so that indicates a blow through! was not sure if maybe my timing was out but i checked that god knows how many times lol
Jimbob-T-Lex
06-04-2020, 09:57 AM #814
Jimbob-T-Lex
Moderator
1,674
ill do a wet test and see what happens to the compression i guess try and pin point the problem
Jimbob-T-Lex
06-04-2020, 09:57 AM #815
Jimbob-T-Lex
Moderator
1,674
06-04-2020, 10:44 AM
wet test results:
Cylinder 1. 156
Cylinder 2. 148
Cylinder 3. 150
Cylinder 4. 159
Cylinder 5. 133
Cylinder 6. 176
Jimbob-T-Lex
06-04-2020, 10:44 AM #816
wet test results:
Cylinder 1. 156
Cylinder 2. 148
Cylinder 3. 150
Cylinder 4. 159
Cylinder 5. 133
Cylinder 6. 176
ZAIS200
06-04-2020, 12:59 PM
Is this due to using the ring you did or another reason? What is the solution otherwise?
ZAIS200
06-04-2020, 12:59 PM #817
Jimbob-T-Lex
Moderator
1,674
06-04-2020, 01:21 PM
no i dont think so but the solution is beyond me at present i done the wet test and its not too bad i need to get a leak down test done really
Jimbob-T-Lex
06-04-2020, 01:21 PM #818
ZAIS200
06-04-2020, 02:03 PM
Aah right, will be interesting to see what the results are
Let us know ok...
ZAIS200
06-04-2020, 02:03 PM #819
Let us know ok...
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 01:59 AM
Right this morning i noticed that there was water from the exhaust so checked my coolant and she is low so could be head gasket is letting water into cylinder
My oil is good no milkyness which is good
My thinking is if water got into my cylinder could this of done my rings in so that i would get blow by as i get smoke from the dipstick?
So basically what im thinking is the whole lot has got to be stripped right down and the head gasket has to be replaced, rings need replacing the worst outcome it could of ever been!!!:Chair:
All i all 4 steps forward 48 back Sad
Oh and to top it off the alternator has give up this morning volts just drop off and she dies lol when it rains it pours!!!
Jimbob-T-Lex
07-04-2020, 01:59 AM #820
 8 Guest(s)
 8 Guest(s)
Views 5,131
09-04-2024, 01:09 AM
Views 1,291
06-04-2024, 05:57 PM
Views 102,881
25-03-2024, 02:10 AM
Views 9,099
23-03-2024, 03:45 PM
Views 20,396
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,490
08-10-2023, 03:59 AM
Views 6,021
06-10-2023, 02:58 AM
Views 3,139
04-10-2023, 03:52 PM
Replies 76
Views 2,818
30-09-2023, 01:24 AM
Last Post by RichS11
