Pages (135): Previous 181 82 83 84 85135 Next
john wan
07-04-2020, 02:10 AM
How much water you sayin? As you know it builds up in the exhaust anyway surely if its that bad coming out then tbere would be signs in the oil or water ?
john wan
07-04-2020, 02:10 AM #821
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 02:58 AM
thats what i thought had an idea though you know the valve thats on the rocker cover to the right the one way valve?? that should be plumbed into the intake manifold right? well mine is not when i connect this up all smoke goes and so does the smoke from the dipstick as this valve is ment to feed some of the gases back into the system to be burnt off but when this sees boost it should shut right?? well all smoke gone but stalls when positive boost is hit what am i doing wrong lol
But this is a gd sign yeah lol??
Jimbob-T-Lex
07-04-2020, 02:58 AM #822
john wan
07-04-2020, 03:06 AM
How much smoke are we talking about?
john wan
07-04-2020, 03:06 AM #823
john wan
07-04-2020, 03:07 AM
What have you done with the breather on the left side of the rocker cover? Cause I would guess that if you were to block both of them off that youd get smoke from the dipstick among other places
Edited 19-05-2013, 12:44 PM by john wan.
john wan
07-04-2020, 03:07 AM #824
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 03:09 AM
thats to the oil catcher mate and then has a breather on the out let of catcher just reading i need a positive crank case pcv the ones used on turbos!!
Jimbob-T-Lex
07-04-2020, 03:09 AM #825
john wan
07-04-2020, 03:11 AM
Undo the catch can make sure thebreather on it is working eh
john wan
07-04-2020, 03:11 AM #826
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 03:16 AM
http://www.junkyardturbos.com/Turbo-PCV-Systems.php
This is what i found!
john wan
07-04-2020, 03:23 AM
Sounds about right mate from what youve said I doubt it would be head gasket as tbere would be signs either mayo or cooling system preasuring same with rings going would have signs to if your running lean youl get water in the exhaust
john wan
07-04-2020, 03:23 AM #828
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 03:32 AM
what does your vacuum sit at mate at idle on yours??
Jimbob-T-Lex
07-04-2020, 03:32 AM #829
john wan
07-04-2020, 07:33 AM
Havnt checked mate what have u been checking with?
john wan
07-04-2020, 07:33 AM #830
 7 Guest(s)
 7 Guest(s)
Views 5,133
09-04-2024, 01:09 AM
Views 1,291
06-04-2024, 05:57 PM
Views 102,881
25-03-2024, 02:10 AM
Views 9,100
23-03-2024, 03:45 PM
Views 20,398
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,490
08-10-2023, 03:59 AM
Views 6,022
06-10-2023, 02:58 AM
Views 3,140
04-10-2023, 03:52 PM
Replies 76
Views 2,818
30-09-2023, 01:24 AM
Last Post by RichS11
