Pages (135): Previous 182 83 84 85 86135 Next
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 08:07 AM
my electronic boost controller and boost gauge mate
Jimbob-T-Lex
07-04-2020, 08:07 AM #831
john wan
07-04-2020, 08:18 AM
Ah haaaaa mine reads 0 as its sat on my shelf **** people am working for just wont let me have a weekend off when its fitted ill be using a manual boost controller and turning it right down then building up from there
john wan
07-04-2020, 08:18 AM #832
07-04-2020, 08:30 AM
I'd guess you should be seeing 22 to 27 inHg
07-04-2020, 08:30 AM #833
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 08:49 AM
Had a gd read just now when i put the pcv valve into my inlet manifold it is sucking alot of air and the AFR goes down to about 11 instead of my steady 14.6
Without the pcv connected my vacuum sits at -14 or -15 but when i connect the pcv it goes to -6 vacuum and i can hear the gases being sucked alot through the pipe
On reading im getting the impression that it shouldnt suck that much air through??
This is what i read
Because the engine idles at low speed there is a relatively small amount of fuel and air traveling through the intake. If the PCV valve did not regulate flow, the engine would act like it had a vacuum leak. Air flowing into the intake might cause the engine to lean out [too much air in relation to the fuel] and misfire. At an idle, the PCV valve restricts air flow, to reduce this problem.
At high manifold vacuum [idle], a spring loaded valve is drawn up and partially restricts flow to the crankcase. On acceleration there is far more volume of fuel and air moving through the engine. Intake manifold vacuum is also much lower. This allows the valve to move to a more central position, increasing fumes drawn from the crankcase. This produces far more removal of fumes, without affecting engine performance.
Should the engine backfire or if the engine is turbo-charged, the PCV valve can also act as a check-valve. Pressure in the intake would cause flow in the opposite direction. By closing the PCV valve, any positive pressure or fuel vapor is prevented from entering the crankcase. Even a very small amount of positive pressure can force oil passed gaskets and seals and blow gaskets out of place.
As the PCV valve ages several things can happen. Crud and sludge can cause it to stick in the open position. This might result in a misfire at idle. Too much air flow acts like a vacuum leak. Excess flow could also draw oil from the engine, causing oil consumption. A quality shop can test this using a tool called a manometer.
What people think?????
Jimbob-T-Lex
07-04-2020, 08:49 AM #834
This is what i read
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 08:52 AM
Well with the pcv not connected i get -14 psi so about 27 inHg
Because the pcv is letting so much gases through its seeing it as a vacuum leak i think?
Jimbob-T-Lex
07-04-2020, 08:52 AM #835
Jimbob-T-Lex
Moderator
1,674
Thanks for help every1!!!
Jimbob-T-Lex
07-04-2020, 08:52 AM #836
07-04-2020, 09:08 AM
Well I don't currently run with a pcv and its fine for me.
07-04-2020, 09:08 AM #837
Jimbob-T-Lex
Moderator
1,674
07-04-2020, 09:23 AM
i wasnt either but this is what rid the gases and blow by so the vapour are burnt this then stops my smoke coming from the rocker and dipstick but as its flowing so much from the pcv its making my a/f ridiculously rich and my vacuum drops like crazy
My mate took his pipe off his pcv and smoke started 5 mins later coming from the dip stick and breather so im assuming and hoping ive not got ridiculous blow by
Jimbob-T-Lex
07-04-2020, 09:23 AM #838
Jimbob-T-Lex
Moderator
1,674
08-04-2020, 11:26 AM
Well all of a sudden today she started to play ball lol i been out driving and all still had a random misfire on 4,5 and 6 but when i looked at the fuel trims bank one was sat at +19.5 constant and bank 2 was changing wierd as im running both off one lambda sensor lol
I was still getting the stall when i boost till waste gate opens but if i change when wastegate opens i can boost harder and go faster till it opens again then stalls again when wastegate opens but got a vid ill post up so you can see where im at she still might make JAPPOWER lol
Jimbob-T-Lex
08-04-2020, 11:26 AM #839
08-04-2020, 01:00 PM
Great news mate!
08-04-2020, 01:00 PM #840
Great news mate!
 8 Guest(s)
 8 Guest(s)
Views 5,133
09-04-2024, 01:09 AM
Views 1,291
06-04-2024, 05:57 PM
Views 102,881
25-03-2024, 02:10 AM
Views 9,100
23-03-2024, 03:45 PM
Views 20,398
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,490
08-10-2023, 03:59 AM
Views 6,022
06-10-2023, 02:58 AM
Views 3,140
04-10-2023, 03:52 PM
Replies 76
Views 2,818
30-09-2023, 01:24 AM
Last Post by RichS11
