Pages (135): Previous 191 92 93 94 95135 Next
john wan
08-06-2020, 09:38 PM
Its gotta be somthing silly as im not getting that problem from what ive done and im not running a pcv
john wan
08-06-2020, 09:38 PM #921
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 02:12 AM
I know that's what's thrown me leak down ok and compression test ok so where the ****** smoke coming from lol
Jimbob-T-Lex
09-06-2020, 02:12 AM #922
john wan
09-06-2020, 02:56 AM
You sure you have all the hoses that go into the head the right way round? Have you got a oil preasure guage set up?
john wan
09-06-2020, 02:56 AM #923
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 03:48 AM
Yeah have oil pressure gauge ill need to see what it reads I'm sure all is ok, hoses on head all I have is water feed to turbo off rear pipe that bolts to head oil feed from banjo bolt PVC not connected and breather pipe not connected which I need to go to turbo inlet could it just be that
Jimbob-T-Lex
09-06-2020, 03:48 AM #924
john wan
09-06-2020, 04:14 AM
You got pickys?
john wan
09-06-2020, 04:14 AM #925
You got pickys?
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 04:25 AM
Ill go out and get some now mate
Jimbob-T-Lex
09-06-2020, 04:25 AM #926
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 04:38 AM
[Image: null_zps7a619034.jpg]
[Image: null_zpsd232d228.jpg]
[Image: null_zpsaca1ad2a.jpg]
[Image: null_zps1d78bca1.jpg]
[Image: null_zps6d16e232.jpg]
[Image: null_zpsd4f5104a.jpg]
[Image: null_zps572a12f1.jpg]
Jimbob-T-Lex
09-06-2020, 04:38 AM #927
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 04:41 AM
right have pipe to map sensor
pipe to brake booster
pipe to boost controller
pipe to BOV
pipe to inlet manifold to vacuum manifold
front of turbo to wastegate and boost solenoid
water feed from back of engine
oil feed to turbo from banjo bolt
Waste oil from turbo to sump
pipe from vacuum manifold to boost gauge
Jimbob-T-Lex
09-06-2020, 04:41 AM #928
pipe to BOV
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 04:42 AM
oh and vacuum manifold to egr valve is it
Jimbob-T-Lex
09-06-2020, 04:42 AM #929
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 04:44 AM
PVC not connected but if i do the afr goes to 10 and stalls at 3k rpm tried to adjust afr no joy still stalls and leans out
breather not connected at the moment need to go to catch can then to turbo inlet right?
Jimbob-T-Lex
09-06-2020, 04:44 AM #930
 3 Guest(s)
 3 Guest(s)
Views 5,134
09-04-2024, 01:09 AM
Views 1,292
06-04-2024, 05:57 PM
Views 102,894
25-03-2024, 02:10 AM
Views 9,102
23-03-2024, 03:45 PM
Views 20,411
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,491
08-10-2023, 03:59 AM
Views 6,022
06-10-2023, 02:58 AM
Views 3,144
04-10-2023, 03:52 PM
Replies 76
Views 2,818
30-09-2023, 01:24 AM
Last Post by RichS11
