Jimbobs Lexus IS200 Turbo!
catch can is connected to the breather then vented from catch can
do you know if there is a restrictor in the pcv pipe as standard just see someone mention it on the net?
thing is my vacuum sit at -16 PSI if i connect the PCV it drops to -1 PSI and richened the system right up basically a vac leak!
Have you give it a sniff? Might be able to smell somthing in it as I was saying before ive been looking at fpr fails an the sites I was looking at said blow past on the pistons so letting fuel into the oil check for fuel in the vac pipe also think it said fuel/oil in the exhaust tip
you got a link im still using the original not got my aftermarket one fitted yet?
http://www.doityourself.com/stry/7-sympt...-regulator
ha ha ha ha shockin have you fitted an uprated pump?
