Pages (132): Previous 194 95 96 97 98132 Next
08-03-2017, 04:48 AM
ok, here we go, pics galore !
The car doesn't really look a lot different from the outside, just a bit lower now, especially at the rear. It was sitting even lower than this at the Ace Cafe, because it had some heavy stuff in the boot. The rear is a bit lower than the front now. Not sure if it's too low, but I haven't had any problems with it so far, and rarely carry people in the back anyway.
[Image: IMG_0088.jpg]
New Black Diamond slotted & drilled brake discs (plus Predator pads) :
[Image: IMG_0095.jpg]
Air/Fuel ratio gauge :
[Image: IMG_0099.jpg]
Coilover adjuster extenders in the boot, so I don't have to remove the boot carpet to adjust the damping ! :
[Image: IMG_0101.jpg]
Stainless brake lines :
[Image: IMG_0104.jpg]
Current gauge pod, very much a work-in-progress, and I'm going to change it now anyway, at least to point the dials towards me :
[Image: IMG_0105.jpg]
Controls for Defi gauges :
[Image: IMG_0107.jpg]
Innovate LC-1 wideband lambda controller :
[Image: IMG_0109.jpg]
Uprated GReddy MAP sensor :
[Image: IMG_0111.jpg]
08-03-2017, 04:48 AM #951
08-03-2017, 04:51 AM
The reason I asked you whether you were running constant wideband at the cafe was because I've heard stories about the LC1 sensor not lasting as long as a narrowband (i.e. stock) sensor... you might need to be replacing it every 3 years.
Not something to worry about now though. The thing I like about this build is that nearly everything looks like it was designed to be there, it all looks in place and in proportion. The car's got a great stance too Smile
08-03-2017, 04:51 AM #952
08-03-2017, 04:52 AM
Engine bay :
[Image: IMG_0108.jpg]
You can see here the oil feed line from the turbo, which comes from low down on one side of the engine, rather than from the VVT-i feed. You can also see the coolant feed lines to the turbo :
[Image: IMG_0112.jpg]
Apexi air filter :
[Image: IMG_0113.jpg]
Tubby tubby tubby ! Big Grin :
[Image: IMG_0114.jpg]
[Image: IMG_0115.jpg]
Downpipe snaking its way past the steering column :
[Image: IMG_0116.jpg]
[Image: IMG_0120.jpg]
You can just about see the big thick flang(e) joining the turbo to the manifold here. It ended up getting re-made because the first one wasn't beefy enough :
[Image: IMG_0117.jpg]
You can just about see the turbo manifold (from IK Engineering) :
[Image: IMG_0119.jpg]
Edited 19-04-2010, 02:28 PM by steviewevie.
08-03-2017, 04:52 AM #953
Engine bay :
Apexi air filter :
08-03-2017, 04:56 AM
[Image: IMG_0121.jpg]
[Image: IMG_0122.jpg]
Uprated fuel injectors :
[Image: IMG_0123.jpg]
Dump valve :
[Image: IMG_0125.jpg]
Oil breather filter :
[Image: IMG_0135.jpg]
Intercooler :
[Image: IMG_0127.jpg]
[Image: IMG_0130.jpg]
Edited 19-04-2010, 02:46 PM by steviewevie.
08-03-2017, 04:56 AM #954
Dump valve :
Intercooler :
[Image: IMG_0131.jpg]
[Image: IMG_0132.jpg]
[Image: IMG_0134.jpg]
[Image: IMG_0133.jpg]
08-03-2017, 04:56 AM #955
08-03-2017, 04:57 AM
toxo The reason I asked you whether you were running constant wideband at the cafe was because I've heard stories about the LC1 sensor not lasting as long as a narrowband (i.e. stock) sensor... you might need to be replacing it every 3 years.
ok, interesting, thanks. I will see how it goes !
Quote:Not something to worry about now though. The thing I like about this build is that nearly everything looks like it was designed to be there, it all looks in place and in proportion. The car's got a great stance too Smile
Thanks :biggrin:
08-03-2017, 04:57 AM #956
Thanks :biggrin:
lexynik
Unregistered
08-03-2017, 04:58 AM
looks great steve-in the pics and in the flesh-didnt take you long to wear the black coating off the disk face did it
lexynik
08-03-2017, 04:58 AM #957
08-03-2017, 05:04 AM
looks great mate. love to see the car in flesh
08-03-2017, 05:04 AM #958
08-03-2017, 05:43 AM
It all looks good (and drives well also), BUT Bandit needs to show you how to polish things like the fuel rail, alternator etc.
08-03-2017, 05:43 AM #959
08-03-2017, 05:45 AM
Yeah now the covers are off there are some more bits to clean up for sure ! I actually brought the tyre foam along to the Ace Cafe in case I got a chance, but was too busy :biggrin:
I am undecided as to whether to try and get a custom cover made, to cover up the ugly bits, or just clean it all up as best I can and leave it on show.
08-03-2017, 05:45 AM #960
Views 5,124
09-04-2024, 01:09 AM
Views 1,289
06-04-2024, 05:57 PM
Views 1,531
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 102,865
25-03-2024, 02:10 AM
Views 9,083
23-03-2024, 03:45 PM
Views 20,370
18-02-2024, 11:42 PM
Views 67,939
08-02-2024, 01:53 AM
Views 404
18-12-2023, 02:55 AM
Views 1,485
08-10-2023, 03:59 AM
Views 3,135
04-10-2023, 03:52 PM
